[mapguide-users] Changing Draw Order Priority of a Temporary Layer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sun May 10 16:11:06 EDT 2009
If you change the MapDefinition, the order will change for new sessions
based on the MapDefinition.
If you want it to change in the current session, you must change the
draw order in the runtime map.
I belive you can remove the layer from the runtime map layer list, and
then re-insert it at the desired location.
Regards, Kenneth Skovhede, GEOGRAF A/S
adnanc skrev:
> Hello all,
> I've created a temporary map layer in the session, which appears fine on the
> map, however it is added as the top most layer. I believe this is the
> default behaviour.
> Any ideas as to how I can modify its draw order priority? Modify the
> MapDefinition document?
> Regards,
> Adnan
