[mapguide-users] help
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon May 11 09:30:09 EDT 2009
Yes, that looks right.
You must also refresh the map (refresh/pan/zoom/etc.) in the browser via
javascript.
In addition to my other suggestions, you can also check the error log
for messages.
Regards, Kenneth Skovhede, GEOGRAF A/S
saloua wakrim skrev:
> hi! please i want know if this code is that what all i must do for
> adding new layer to map and see it in viewer frame or i must do some
> relation with the feature source i create in my code?? thanks on advance
> myLayer =
> New MgLayer(layerDefId, resourceSrvc)
> myLayer.SetName(myLayerName)
> myLayer.SetLegendLabel(myLayerName)
> myLayer.SetDisplayInLegend(
> True)
> myLayer.SetSelectable(
> False)
> map.GetLayers().Insert(0, myLayer)
> myLayer.ForceRefresh()
> map.Save(resourceSrvc)
> 2009/5/10 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>>
> The code looks alright.
> Do you refresh the map afterwards?
> What is in the "insertResults" ?
> (There can be a hidden error, due to a bug in MapGuide)
> Are you sure that the LayerDefinition matches the FeatureSource?
> Try to create the FeatureSource and LayerDefinition in
> "Library://" instead,
> so you can examine the layer from Studio/Maestro.
>> i try the following code for displaying layer wich contains line
>> in map, so i digitize a line, create temporary feature for this
>> line, create a layer wich contains it and add it to the map. it
>> doesn't give me some error but i can see the line in the map (i
>> can draw it). Please help me. the code is following:
>> String
>> dataSource = "Session:" + sessionid1 + "//" + myLayerName +
>> ".FeatureSource"; MgResourceIdentifier dataSourceId = new
>> MgResourceIdentifier(dataSource); MgFeatureService featureSrvc =
>> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>> if (DoesLayerExist(myLayerName, map) == false)
>> //create Feature Source MgClassDefinition myClassDef = new
>> MgClassDefinition();
>> myClassDef.SetName(myLayerName);
>> myClassDef.SetDescription(myLayerName +
>> " Feature Source");
>> myClassDef.SetDefaultGeometryPropertyName(
>> "SHPGEOM"); MgDataPropertyDefinition prop = new
>> MgDataPropertyDefinition("KEY");
>> prop.SetDataType(
>> MgPropertyType.Int32);
>> prop.SetAutoGeneration(
>> true);
>> prop.SetReadOnly(
>> true);
>> myClassDef.GetIdentityProperties().Add(prop);
>> myClassDef.GetProperties().Add(prop);
>> prop =
>> new MgDataPropertyDefinition("ID");
>> prop.SetDataType(
>> MgGeometricPropertyDefinition geomProp = new
>> MgGeometricPropertyDefinition("SHPGEOM");
>> geomProp.SetGeometryTypes(
>> MgFeatureGeometricType.Curve);
>> myClassDef.GetProperties().Add(geomProp);
>> MgFeatureSchema schema = new MgFeatureSchema(myLayerName +
>> "Schema", myLayerName + "SchemaDesc");
>> schema.GetClasses().Add(myClassDef);
>> MgCreateSdfParams sdfParams = new MgCreateSdfParams("MGA-56
>> (GDA94 / MGA zone 56)", map.GetMapSRS(), schema);
>> featureSrvc.CreateFeatureSource(dataSourceId, sdfParams);
>> //create layer //String layerDef = "Session:" + sessionid1 + "//"
>> + myLayerName + ".LayerDefinition"; MgResourceIdentifier
>> layerDefId = new
>> MgResourceIdentifier("Library://essaicalque/Redline.LayerDefinition");
>> MgByteSource content = new MgByteSource(@"C:\Program
>> Files\MapGuideOpenSource\WebServerExtensions\www\essaiselect2\Layerdef.xml");
>> resourceSrvc.SetResource(layerDefId, content.GetReader(),
>> null); //code enlev‚ d'ici: ajouter layer resource … la carte
>> //il faut ajouter l'autre code: add layer resource to map
>> //DOMDocument domdoc = new DOMdocument(); MgLayer
>> result=add_layer_resource_to_map(layerDefId,resourceSrvc,myLayerName,myLayerName,map);
>> MgInsertFeatures insertFeatures = new
>> MgInsertFeatures(myLayerName, makeLine("1", x0, y0, x1, y1));
>> MgFeatureCommandCollection commands = new
>> MgFeatureCommandCollection();
>> commands.Add(insertFeatures);
>> int commandIndex = commands.IndexOf(insertFeatures);
>> MgPropertyCollection insertResults;
>> insertResults = featureSrvc.UpdateFeatures(dataSourceId, commands,
>> false); MgLayer myLayer1 = map.GetLayers().GetItem(myLayerName)
>> as MgLayer;
>> myLayer1.ForceRefresh();
>> //commands.Add(new MgInsertFeatures(myLayerName,makeLine("1", x0,
>> y0, x1, y1)));
>> map.Save(resourceSrvc);
>> script runat=server> Boolean result; MgPropertyCollection
>> makeLine(String Name, Double x0, Double y0, Double x1, Double y1)
>> MgPropertyCollection PropertyCollection = new
>> MgPropertyCollection(); MgInt32Property nameProperty = new
>> MgInt32Property("ID", 1);
>> PropertyCollection.Add(nameProperty);
>> MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
>> MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
>> MgGeometry geometry = wktReaderWriter.Read("LINESTRING XY (" + x0
>> + " " + y0 + "," + x1 + " " + y1 + ")") as MgLineString;
>> //MgGeometry geometry = wktReaderWriter.Read("LINESTRING(3 4,10
>> 50,20 25)") as MgLineString; MgByteReader geometryByteReader =
>> agfReaderWriter.Write(geometry); MgGeometryProperty
>> geometryProperty = new MgGeometryProperty("SHPGEOM",
>> geometryByteReader);
>> PropertyCollection.Add(geometryProperty);
>> return PropertyCollection;
>> Boolean
>> DoesLayerExist(String LayerName, MgMap Map)
>> MgLayerCollection layers = Map.GetLayers();
>> result = (layers.Contains(myLayerName));
>> return result;
>> MgLayer add_layer_resource_to_map(MgResourceIdentifier
>> layerresourceid, MgResourceService rs, String layername, String
>> layerlegendlabel, MgMap map)
>> MgLayer myLayer = new MgLayer(layerresourceid, rs);
>> myLayer.SetName(layername);
>> myLayer.SetLegendLabel(layerlegendlabel);
>> true);
>> true);
>> if (!map.GetLayers().Contains(layername))
>> map.GetLayers().Insert(0, myLayer);
>> myLayer.SetVisible(
>> true);
>> myLayer.ForceRefresh();
>> return myLayer;
>> script>
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090511/05ba4b98/attachment.html
