[mapguide-users] Changing Draw Order Priority of a Temporary Layer
saloua wakrim wakrimsaloua.wakrim at gmail.com
Mon May 11 11:22:37 EDT 2009
hi adnanc, please if your code wish insert the layer in the map and allow
you to see it after refreshing map runs well, send it to me if you want, i
don't see my error and i spent a lot of my time for doing that but no way...
2009/5/8 adnanc <adnan.chughtai at keynetix.com>
> Hello all,
> I've created a temporary map layer in the session, which appears fine on
> the
> map, however it is added as the top most layer.  I believe this is the
> default behaviour.
> Any ideas as to how I can modify its draw order priority? Modify the
> MapDefinition document?
> Regards,
> Adnan
> http://n2.nabble.com/Changing-Draw-Order-Priority-of-a-Temporary-Layer-tp2845838p2845838.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090511/9b4312cb/attachment.html
