[mapguide-users] Mapguide Site Login Problem
tejaswi
tejaswi_a at rediffmail.com
Tue May 12 05:34:14 EDT 2009
hi
Even i had gone through the same problem..I am using autodesk mapguide 2009.
I re-installed all the three Server,web server extensions and studio.
also re installed framework and restarted my IIS.
Then it started working .
you please try to re install mapguide.
Also use you IP address instead of local host.
thanks & regards
Tejaswi
View this message in context: http://n2.nabble.com/Mapguide-Site-Login-Problem-tp2866923p2868219.html
