[mapguide-users] .NET viewer sample: query tool
Jackie Ng jumpinjackie at gmail.com
Tue May 12 07:32:29 EDT 2009
If you look at the server error logs, do they reveal any more information at
the time of failure?
- Jackie
nasp wrote:
> Thank you for your answer.
> Mapguide version is 2.0.2 with FDO 3.4
> The map has EPSG=3003
> Any ideas?
> Jackie Ng wrote:
>> Are you using the latest release of MapGuide?
>> Also, do your maps/layers/feature sources have defined coordinate
>> systems?
>> - Jackie
>> nasp wrote:
>>> Hi,
>>> I downloaded .NET sample application.
>>> Everything works fine but not the query tool.
>>> In query\classes\query.aspx, Execute() procedure, I got an error
>>> (MgUnclassifiedException) at this line
>>>                 centerPoint = (MgPoint)
>>> centerPoint.Transform(csTransform);
>>> Can someone help me, please?
>>> Regards,
>>> Naspi
View this message in context: http://n2.nabble.com/.NET-viewer-sample%3A-query-tool-tp2868356p2868607.html
