[mapguide-users] migrating resources from 2009 server to 2010
Steve Dang
steve.dang at autodesk.com
Tue May 12 15:38:34 EDT 2009
One more thing - The packages only work with the Library repository. So, you will lose all the user information in the Site repository.
Steve.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Tuesday, May 12, 2009 1:28 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] migrating resources from 2009 server to 2010
The packages work well with small repositories. As long as all the resource headers are included in the packages (they should), the permissions should be preserved.
Steve.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Tuesday, May 12, 2009 1:12 PM
To: 'MapGuide Users Mail List'
I haven't had any issues with items 2 and 3 when I've done this in the past
for a package that's about 1 GB. I agree, larger packages would be less
manageable. I see your point on item 1 but I don't use resource-based
permissions, but certainly something for others to be aware of.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, May 12, 2009 12:05 PM
Here's a few things I can think of:
- you don't preserve permissions when you go the package route
- it takes longer to generate the package
- it's relatively easy to overflow the maximum package size if you're using
managed data.
Jason
Sent: Tuesday, May 12, 2009 11:53 AM
Is there anything wrong with Jackie's approach of loading a 2009 package on
a 2010 site? That's my preferred method as well instead of having to run
through the below steps.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
