[mapguide-users] Selection problem with King.Oracle provider
Simon Pelicon simon at sl-king.com
Wed May 13 02:46:39 EDT 2009
Hi!
It looks like that there is some problem with primary key field you
defined.
What data type is OID column?
Check if data are ok in OID column.
Simon
Andreas Morf wrote:
> Within a project I switched from SDF provider to king.oracle (0.8.9)  and
> now, selection in fusion doesn't work anymore for same data (no error, but
> no highlighting nor attributes)
> After investigating a little bit I found the following Selection-XML in
> Query.php:
> King.Oracle:
> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
> id="b3eefd0c-ffff-ffff-8000-00187186e6ed">  <Class
> id="KingOra:GEORI_AV~AV_BB_GEBAEUDE~GEOMETRY">   <ID>AAAAAA==</ID>
> <ID>AAAAAA==</ID>   <ID>AAAAAA==</ID>   <ID>AAAAAA==</ID>
> <ID>AAAAAA==</ID>   <ID>AAAAAA==</ID>  </Class> </Layer></FeatureSet>
> This, of course doesn't make lot of sense...
> A primary key was set with fdo2fdo for a column named 'OID'
> Any explanation for this problem?
> Thanks, Andreas
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
