[mapguide-users] Modifying SymbolDefinition programmatically
psciga
scigalla at battefeld.com
Wed May 13 04:49:44 EDT 2009
Hello,
can you tell me please, how to modify the symbol definition with php?
Following background:
In AutoCAD I have several hundred blocks. The import into MGOS 2 via MG
Studio 2009 works fine. The once problem is, that the parameter for ROTATION
have a DefaultValue = 0. This default value I want to replace with a field
name "winkel" from the MySQL database. It is easy to do this by hand for
some symbols, but with for 657 symbol definitions I become crazy ;-) .
How can I replace this default value using php?
Thanks in advance.
Regards - Peter
View this message in context: http://n2.nabble.com/Modifying-SymbolDefinition-programmatically-tp2879871p2879871.html
