[mapguide-users] Mapguide Server SPecs...
Martin Morrison
martin.morrison at edsi.com
Thu May 14 11:12:40 EDT 2009
Agreed on the disk performance. Even though Mapguide is currently a 32 bit primarily single threaded app, it's not going to stay that way forever. Do get a server that 64-bit. Mutli-cores and multi-processor capable. A 32 bit app (with large address aware turned on) running on a 64-bit server will have 4 GB of ram available to it, rather than 2GB (or 3 with the switch added). Memory is cheap, buy lot's of it.
Do consider putting data in a SQL spatial database, this has the benefit of off-loading some of the datareads.
If you need more help let, me know.
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, May 14, 2009 10:33 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide Server SPecs...
good disk perfromance is really important, consider SSD's
On Fri, May 15, 2009 at 12:29 AM, Scott Sonnier <ScottS at suncoastland.com> wrote:
> What are the common specifications for a working Windows Server 2003 box to
> run Mapguide OS?
> Hosting will include data-Entire Counties and Aerial Photos...
> Do I need anything special when putting this server together?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
