[mapguide-users] Performance Problem using DWF
Luis Paolini
l_paolini at uol.com.br
Fri May 15 09:00:35 EDT 2009
Martin,
I did not audited the dwg and to be honest, I don't know how
to do it.
These auditing operations should be done using Mapguide?
Luis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: Friday, May 15, 2009 9:49 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Performance Problem using DWF
Something is wrong with the larger dwg. Have you audited the dwg? Run
MapCleanup? Purge? Cleaned up excessive scales?
Martin
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Luis Paolini
Sent: Friday, May 15, 2009 8:32 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Performance Problem using DWF
I'm a new Mapguide user and need some help to fix a performance problem
publishing DWF data.
Using Autodesk Map 3D I published a DWG to Mapguide. The DWG file has
10Mbytes and the processo took 7 hours. I think that it is too much time and
something must be wrong but let's move on.
After that, using Autodesk Studio, I tried to preview the layer created
(DWF) and the preview windows keeps retrieving data forever and shows
nothing. At the other side, Mapguide Server Processe allocate a lot of my
server resources (memory and CPU) for hours and do nothing.
I also configured the layer to accept WMS requests, but when I send a
GetMap request the same problem happens. No map is returned and the server
resources are increased.
I did the same process with a smaller file (1 Mbyte) and it worked
pretty fine. This small file has the same layers that the big one, but with
less features.
Have you guys some ideas?
Regards,
Luis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090515/db6a43da/attachment.html
