[mapguide-users] Teleatlas Multinet stylesheet ??
Ludovic Gnemmi
lgnemmi at rgd.fr
Fri May 15 09:08:14 EDT 2009
Yes you are right. But i don't want to increase the number of map servers.
There is already enough work to maintain one server :)
nasp wrote:
> I'm new to this subject, but I think you can create a Web Mapping Service
> (WMS) using OpenGis SLD.
> Mapguide supports WMS, so you can indirectly integrate Teleatlas
> cartografy and Mapguide.
> Is that right? Is it a good solution for you?
> Naspi
> Ludovic Gnemmi wrote:
>> Hi,
>> Unfortunately not. It must be said that the work is very complex. I found
>> a Teleatlas White Paper and SLD samples for GeoServer. But nothing for
>> Mapguide. I really regret that Mapguide does not support OpenGis SLD.
>> Such a stylesheet for MultiNet could really help the community.
>> Ludovic
>> nasp wrote:
>>> Hi,
>>> did you find a way to work with Teleatlas Multinet Database and
>>> Mapguide?
>>> Regards,
>>> Naspi
>>>> Hi list, i have to work with Telatlas dateset to produce google like
>>>> styled map. I was wondering if someone had already worked on the
>>>> rendering of layers comming fromTeleatlas Multinet Database product.
>>>> Is there any stylesheet for Mapguide? Any help would be very welcome.
>>>> Ludovic
View this message in context: http://n2.nabble.com/Teleatlas-Multinet-stylesheet----tp2414470p2907662.html
