[mapguide-users] Mapguide maestro login problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue May 19 02:38:29 EDT 2009
You have a corrupt/broken repository.
The easiest way to fix this, is to restore a backup of the repository.
If you know what file/folder is the culprit you can either delete it, or
upload a correct header.
You can obtain a header from any of the working resources.
You cannot use Maestro or any other tool that I know of to get this working,
instead you must manually use the web form:
http://localhost/mapguide/mapagent/mapagent.fcgi
Try to use "EnumerateResources" to figure out what resource/folder is
broken,
then use GetResourceHeader to get a working header, and SetResource to
upload the working header.
Again, its much easier to just restore a backup MGP or whatever backup
you have.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> iam using mapguide opensource 2..0 (with .net 2.0+IIS 5.1+win xp)
> and iam using mapguide maestro for creating packages.
> While connecting to the maestro i got the following
> error....................................
> http://n2.nabble.com/file/n2932139/maestro.jpeg
> can anybody plz tell me the solution???????????????????????????????????????/
> Regards,
> Padmini.
