[mapguide-users] Minimum install to use PHP/AJAX maps on Windows servers
Zac Spitzer zac.spitzer at gmail.com
Tue May 19 03:30:33 EDT 2009
On Tue, May 19, 2009 at 5:26 PM, shepwaydistrictcouncil
<neil.thompson at shepway.gov.uk> wrote:
> Thanks Zac
> So basically,
> web server : install the webextensions (where do I need to configure these
> to know where the MGOS server is please?)
> appserver : install mapguideos server
the installer will ask you for the options, you just need to provide
the ip address of your mapguide server
> Then the files viewed on from the webserver will map to the data server from
> MGOS on the appserver?
yep
> Here is how we currently run using MG6.5 :
> http://www.shepway.gov.uk/webapp/map2/
> Thanks so much for replying so quickly,
> Neil
> View this message in context: http://n2.nabble.com/Minimum-install-to-use-PHP-AJAX-maps-on-Windows-servers-tp2937896p2937963.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
