[mapguide-users] Buffer Creation
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed May 20 03:35:23 EDT 2009
You need to use the MgSelection object:
http://mapguide.osgeo.net/files/mapguide/docs/webapi/d7/d8d/class_mg_selection.html
When you have set the correct selection, call save on MgSelection.
Regards, Kenneth Skovhede, GEOGRAF A/S
tejaswi skrev:
> hi
> I have to do 2 things in my application
> 1. Select a point from a query function that i have called.Once the point is
> selected I have to create a buffer of 1km above this selection point.
> I able to select the point through my programming and create the buffer
> also(I am creating the buffer function by building my own code not using the
> default buffer function).
> 2. Now once the buffer is showing on the map.its initial state should be
> selected , i should not select it manually on the map using the
> pointer(mouse).
> I am not able to do this.
> I am putting in the code for creating buffer....
> public void create_buffer()
>         siteConnection = new MgSiteConnection();
>         userInfo = new MgUserInformation(mgsessionid);
>         siteConnection.Open(userInfo);
>         featureService =
> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>         resourceService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>         mapDefinition = "Library://DELHI/Maps/DelhiMap.MapDefinition";
>         resId = new MgResourceIdentifier(mapDefinition);
>         mapName = resId.GetName();
>         map.Open(resourceService, mapName);
>         Lays = map.GetLayers();
>         //Response.Write(resourceService.GetResourceContent(resId));
>         //map.Save(resourceService);
>         if (ddl_buffer.Text == "1Km")
>             bufferRingSize = 0.003;//0.01;
>         if (ddl_buffer.Text == "3Km")
>             bufferRingSize = 0.007;//0.02;
>         if (ddl_buffer.Text == "5Km")
>             bufferRingSize = 0.015;//0.04;
>         //LayerName = ddl_layers.Text;
>         //Response.Write(bufferRingSize);
>         try
>             //btn_select_within.Visible = true;
>             //btn_buffer_report.Visible = true;
>             //lblERR.Visible = false;
>             MgSelection selection = new MgSelection(map);
>             //Response.Write(selection.GetLayers().GetCount());
>             selection.Open(resourceService, mapName);
>             LayerName = selection.GetLayers().GetItem(0).GetName();
>             layer = LayerByName(map, LayerName);
>             //Response.Write(layer.GetName());
>             string LayerClassName = layer.GetFeatureClassName();
>             string selectionString = "";
>             selectionString = selection.GenerateFilter(layer,
> LayerClassName);
>             string LayerFeatureId = layer.GetFeatureSourceId();
>             MgResourceIdentifier LayerFeatureResource = new
> MgResourceIdentifier(LayerFeatureId);
>             queryOptions = new MgFeatureQueryOptions();
>             queryOptions.SetFilter(selectionString);
>             featureReader =
> featureService.SelectFeatures(LayerFeatureResource, LayerClassName,
> queryOptions);
>             if (selectionString != "")
>                 //Response.Write("Selected Feature-->" + selectionString);
>                 bufferRingCount = 3.0;
>                 string mapWktSrs = map.GetMapSRS();
>                 MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
>                 MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
>                 MgCoordinateSystemFactory coordSysFactory = new
> MgCoordinateSystemFactory();
>                 MgCoordinateSystem srs = coordSysFactory.Create(mapWktSrs);
>                 MgCoordinateSystemMeasure srsMeasure = srs.GetMeasure();
>                 MgResourceIdentifier bufferFeatureResId;
>                 MgLayerBase bufferLayer;
>                 // Check for a buffer layer. If it exists, delete
>                 // the current features.
>                 // If it does not exist, create a feature source and
>                 // a layer to hold the buffer.
>                 MgLayerBase bufferLayer1 = LayerByName(map, "Buffer");
>                 if (bufferLayer1 == null)//try
>                     bufferFeatureResId = new MgResourceIdentifier("Session:"
> + mgsessionid + "//Buffer.FeatureSource");
>                     CreateBufferFeatureSource(featureService, mapWktSrs,
> bufferFeatureResId);
>                     bufferLayer = CreateBufferLayer(resourceService,
> bufferFeatureResId, mgsessionid);
>                     map.GetLayers().Insert(0, bufferLayer);
>                     bufferLayer.ForceRefresh();
>                     //Response.Write("<script type=text/javascript>");
>                     //Response.Write("parent.parent.mapFrame.Refresh();");
>                     //Response.Write("</script>");
>                     //bufferLayer = map.GetLayers().GetItem("Buffer");
>                     //bufferFeatureResId = new
> MgResourceIdentifier(bufferLayer.GetFeatureSourceId());
>                     //MgFeatureCommandCollection commands = new
> MgFeatureCommandCollection();
>                     //commands.Add(new MgDeleteFeatures("BufferClass", "ID
> like '%'"));
>                     //featureService.UpdateFeatures(bufferFeatureResId,
> commands, false);
>                 else//catch (MgObjectNotFoundException e)
>                     RemoveLayer(map, "Buffer");
>                     // When an MgObjectNotFoundException is thrown, the
> layer
>                     // does not exist and must be created.
>                 Double srsDist =
> srs.ConvertMetersToCoordinateSystemUnits(bufferRingSize);
>                 MgGeometry featureGeometry;
>                 MgLayerCollection selectedLayers = map.GetLayers();
>                 for (int i = 0; i < selectedLayers.GetCount(); i++)
>                     // Only check selected features in the Parcels layer.
>                     layer = selectedLayers.GetItem(i);
>                     if (layer.GetName() == LayerName)
>                         // Create a filter containing the IDs of the
> selected features on this layer
>                         String layerClassName = layer.GetFeatureClassName();
> layerClassName);
>                         // Get the feature resource for the selected layer
>                         String layerFeatureId = layer.GetFeatureSourceId();
>                         MgResourceIdentifier layerFeatureResource = new
> MgResourceIdentifier(layerFeatureId);
>                         // Apply the filter to the feature resource for the
> selected layer. This returns
>                         // an MgFeatureReader of all the selected features.
>                         featureReader =
> featureService.SelectFeatures(layerFeatureResource, layerClassName,
> queryOptions);
>                         // Process each item in the MgFeatureReader. Get the
>                         // geometries from all the selected features and
>                         // merge them into a single geometry.
>                         MgGeometryCollection inputGeometries = new
> MgGeometryCollection();
>                         while (featureReader.ReadNext())
>                             //SHPGEOM
>                             MgByteReader featureGeometryData =
> featureReader.GetGeometry("Geometry");
>                             featureGeometry =
> agfReaderWriter.Read(featureGeometryData);
>                             inputGeometries.Add(featureGeometry);
>                         MgGeometryFactory geometryFactory = new
> MgGeometryFactory();
>                         MgMultiGeometry mergedGeometries =
> geometryFactory.CreateMultiGeometry(inputGeometries);
>                         // Add buffer features to the temporary feature
> source.
>                         // Create multiple concentric buffers to show area.
>                         // If the stylization for the layer draws the
> features
>                         // partially transparent, the concentric rings will
> be
>                         // progressively darker towards the center.
>                         // The stylization is set in the layer template
> file, which
>                         // is used in function CreateBufferLayer().
>                         for (int bufferRing = 0; bufferRing <
> bufferRingCount; bufferRing++)
>                             //Double bufferDist =
> srs.ConvertMetersToCoordinateSystemUnits(bufferRingSize * (bufferRing + 1));
>                             Double bufferDist = bufferRingSize *(bufferRing
> + 1);
>                             bufferGeometry =
> mergedGeometries.Buffer(bufferDist, srsMeasure);
>                             MgPropertyCollection properties = new
> MgPropertyCollection();
>                             properties.Add(new
> MgGeometryProperty("BufferGeometry",
> agfReaderWriter.Write(bufferGeometry)));
>                             //MgByteReader featureGeometryData =
>                             //featureGeometry =
>                             commands.Add(new MgInsertFeatures("BufferClass",
> properties));
>                         MgPropertyCollection results =
> featureService.UpdateFeatures(bufferFeatureResId, commands, false);
>                         bufferLayer.SetVisible(true);
>                         bufferLayer.SetSelectable(true);
>                         bufferLayer.SetDisplayInLegend(true);
>         catch (NullReferenceException f)
>             Response.Write("No selection");
>             //btn_select_within.Visible = false;
>             //btn_buffer_report.Visible = false;
>             //lblERR.Visible = true;
>             //lblERR.Text = "Select Parcel On Map";
> public void CreateBufferFeatureSource(MgFeatureService featureService,
> String wkt, MgResourceIdentifier bufferFeatureResId)
>         MgClassDefinition bufferClass = new MgClassDefinition();
>         bufferClass.SetName("BufferClass");
>         MgPropertyDefinitionCollection properties =
> bufferClass.GetProperties();
>         MgDataPropertyDefinition idProperty = new
> MgDataPropertyDefinition("ID");
>         idProperty.SetDataType(MgPropertyType.Int32);
>         idProperty.SetReadOnly(true);
>         idProperty.SetNullable(false);
>         idProperty.SetAutoGeneration(true);
>         properties.Add(idProperty);
>         MgGeometricPropertyDefinition polygonProperty = new
> MgGeometricPropertyDefinition("BufferGeometry");
>         polygonProperty.SetGeometryTypes(MgFeatureGeometricType.Surface);
>         polygonProperty.SetHasElevation(false);
>         polygonProperty.SetHasMeasure(false);
>         polygonProperty.SetReadOnly(false);
>         polygonProperty.SetSpatialContextAssociation("defaultSrs");
>         properties.Add(polygonProperty);
>         MgPropertyDefinitionCollection idProperties =
> bufferClass.GetIdentityProperties();
>         idProperties.Add(idProperty);
>         bufferClass.SetDefaultGeometryPropertyName("BufferGeometry");
>         MgFeatureSchema bufferSchema = new
> MgFeatureSchema("BufferLayerSchema", "temporary schema to hold a buffer");
>         bufferSchema.GetClasses().Add(bufferClass);
>         MgCreateSdfParams sdfParams = new MgCreateSdfParams("defaultSrs",
> wkt, bufferSchema);
>         featureService.CreateFeatureSource(bufferFeatureResId, sdfParams);
> public MgLayer CreateBufferLayer(MgResourceService resourceService,
> MgResourceIdentifier bufferFeatureResId, String sessionId)
>         // Load the layer definition template into
>         // a  DOM object, find the "ResourceId" element, and
>         // modify its content to reference the temporary
>         // feature source.
>         XmlDocument doc = new XmlDocument();
>         doc.PreserveWhitespace = false;
>         doc.Load(Request.ServerVariables["APPL_PHYSICAL_PATH"] +
> "bufferlayerdefinition.xml");
>         XmlNode featureSourceNode =
> doc.GetElementsByTagName("ResourceId").Item(0);
>         XmlNode resContent =
> doc.CreateTextNode(bufferFeatureResId.ToString());
>         featureSourceNode.AppendChild(resContent);
>         //featureSourceNode.nodeValue = bufferFeatureResId.ToString();
>         // Get the updated layer definition from the DOM object
>         // and save it to the session repository using the
>         // ResourceService object.
>         MemoryStream xmlStream = new MemoryStream();
>         doc.Save(xmlStream);//saveXML();
>         byte[] layerDefinition = xmlStream.ToArray();
>         Encoding utf8 = Encoding.UTF8;
>         String layerDefStr = new String(utf8.GetChars(layerDefinition));
>         layerDefinition = new byte[layerDefStr.Length - 1];
>         int byteCount = utf8.GetBytes(layerDefStr, 1, layerDefStr.Length -
> 1, layerDefinition, 0);
>         MgByteSource byteSource = new MgByteSource(layerDefinition,
> layerDefinition.Length);
>         byteSource.SetMimeType(MgMimeType.Xml);
>         MgResourceIdentifier tempLayerResId = new
> MgResourceIdentifier("Session:" + sessionId + "//Buffer.LayerDefinition");
> //Response.Write(resourceService.ResourceExists(tempLayerResId));//--Error
> "NOT IMPLEMENTED"
>         resourceService.SetResource(tempLayerResId, byteSource.GetReader(),
> null);
>         // Create an MgLayer object based on the new layer definition
>         // and return it to the caller.
>         MgLayer bufferLayer = new MgLayer(tempLayerResId, resourceService);
>         bufferLayer.SetName("Buffer");
>         bufferLayer.SetLegendLabel("Buffer");
>         bufferLayer.SetSelectable(false);
>         return bufferLayer;
> Kindly suggest me wat to do..
> Thanking you,
> Regards
> Tejaswi.
