[mapguide-users] Trying to add another class definition to a SDF
Rodolfo Moreno
rmoreno at voxiva.com
Thu May 21 10:53:23 EDT 2009
Jackie and how can I use the FDO API into Magguide applications? do you get
some code sample about it?
Regards,
Jackie Ng wrote:
> MapGuide does not expose FDO's IApplySchema command. You will have to use
> the FDO API directly if you want to modify existing schemas.
> - Jackie
> Jamo wrote:
>> I've been trying this code to add another class definition to a SDF, it
>> only adds a new classDefinition when the users SDF already exists.... is
>> this possible, everything seems to run through fine .... but no new
>> class..
>> if (ResourceService.ResourceExists(dataSourceId) == false)
>> //create Feature Source
>> MgClassDefinition myClassDef = new MgClassDefinition();
>> myClassDef.SetName(layerName);
>> myClassDef.SetDescription(layerDesc);
>> //TODO : make SHPGEOM a Variable...
>> myClassDef.SetDefaultGeometryPropertyName("GEOM");
>> //Set KEY Property
>> MgDataPropertyDefinition prop = new
>> MgDataPropertyDefinition("FeatId");
>> prop.SetDataType(MgPropertyType.Int32);
>> prop.SetAutoGeneration(true);
>> prop.SetReadOnly(true);
>> myClassDef.GetIdentityProperties().Add(prop);
>> myClassDef.GetProperties().Add(prop);
>> //Set geometry property
>> MgGeometricPropertyDefinition geomProp = new
>> MgGeometricPropertyDefinition("GEOM");
>> geomProp.SetGeometryTypes(MgFeatureGeometricType.Curve);
>> myClassDef.GetProperties().Add(geomProp);
>> //Create the schema
>> MgFeatureSchema schema = new MgFeatureSchema("Default", "Default
>> Feature Schema");
>> schema.GetClasses().Add(myClassDef);
>> MgCreateSdfParams sdfParams = new MgCreateSdfParams("MGA-56
>> (GDA94 / MGA zone 56)", map.GetMapSRS(), schema);
>> FeatureService.CreateFeatureSource(dataSourceId, sdfParams);
>> else
>> //Set KEY Property
>> FeatureService.DescribeSchema(dataSourceId,
>> "Default")[0].GetClasses().Add(myClassDef);
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Trying-to-add-another-class-definition-to-a-SDF-tp2950536p2952391.html
