[mapguide-users] prob with GetSelectionXml()
wakrimsaloua.wakrim at gmail.com
Tue May 26 11:13:32 EDT 2009
hi all! i've prob with use the xml selection wich i get after user clic on polygone, this is javascript function i use to get selection:(i write it in textfiel and read it by Request.Form:
function test()
k= document.formulaire.classe.value=carte.GetMapFrame().GetSelectionXML();
for get this selection i use this code
selectionXml = getValue("classe")
Private Function getValue(ByVal champ As String) As String
' récupère la valeur du champ [champ] de la requête postée
' qq chose ?
If Request.Form(champ) Is Nothing Then Return ""
' on récupère la ou les valeurs du champ
Dim valeurs() As String = Request.Form.GetValues(champ)
Dim valeur As String = ""
Dim i As Integer
For i = 0 To valeurs.Length - 1
valeur += valeurs(i)
Next
valeur = Server.UrlDecode(valeur)
Return valeur
End Function
after user clic on polygone and get xml selection , i use this code for filter and identify polygone ID:
Public Sub getselectionpartiel(ByVal map As MgMap, ByVal resourceService As MgResourceService, ByVal XmlSel As String)
Dim k = 0
If ((XmlSel <> Nothing) And (XmlSel <> "")) Then
Dim selection As New MgSelection(map, XmlSel)
Dim Layers As MgReadOnlyLayerCollection = selection.GetLayers()
If Not Layers.GetCount = 1 Then
Response.Write("More than one object was selected")
Exit Sub
End If
Response.Write("calques selectionnés")
End If
End Sub
and i call this function like that:
getselectionpartiel(map, resourceSrvc, selectionXml)
it gives me this error:
"La référence d'objet n'est pas définie à une instance d'un objet." in the line:
(the object reference is not associated to the object instance)
i think that Layers is empty but when i display "selectionXml" by using:
Response.Write(selectionXml) it gives me the correct selection!!!
if some one has some idea please tell it me, thanks a lot on advance
