[mapguide-users] Oracle FDO and View
GordonL
gordon.luckett at arrowgeomatics.com
Tue May 26 16:51:05 EDT 2009
Yep, the materialized view has its own key - but still the individual objects
cannot be selected within MapGuide. The same data in the traditional table
work fine. Very weird.
gordon
Dave Wilson wrote:
> A materialized view might need its own primary key defined as it's
> basically a table.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
> Sent: Tuesday, May 26, 2009 2:37 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Oracle FDO and View
> Yes, it does work, but it does not allow me to select features in the map.
> For example, I have a materialize view called MVIEW_PARCELS, it has a
> spatial index on the GEOMETRY column and index on the GIS_ID column. It
> has
> a row in the MDSYS.SDO_GEOM_METADATA_TABLE.
> I can see everything on the map in MapGuide, but I cannot select
> individual
> parcels.
> gordon
> Dave Wilson wrote:
>> Actually you can use a view if it includes the primary key column from
>> the
>> underlying geometry table. You also have to add user_sdo_geom_metadata
>> records for the view. Basically insert by copying the entry for the
>> underlying table that has the geometry.
>> It should work without the materialized view.
>> At least it does with the Autodesk Oracle provider.
>> Dave
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Hequet
>> Sent: Wednesday, May 20, 2009 7:24 AM
>> With Oracle you can add primary key (don't confuse index and Key) to view
>> (sorry i don't have the sql here).
>> Materialized view is a good way to improve performance (espacially if you
>> use view on multiple database).
>> Haris Kurtagic wrote:
>>> Yes, you need to create materialized view for index or you can use
>>> KingFdoClass metadata table to tell provider which column will be used
>>> as primary key.
>>> Haris
>>> Sent: Wednesday, May 20, 2009 3:05 PM
>>> Subject: Re: [mapguide-users] Oracle FDO and View
>>> Thanks David,
>>> Index on a view? The core tables are already indexed - including the
>>> GEOMETRY column. Do you mean convert it to a MATERIALIZED VIEW and
>>> index it
>>> then?
>>> thanks
>>> gordon
>>> David Hequet wrote:
>>>> Hi,
>>>> Features can be selectable if you add primary key to your view
>>> (MapGuide
>>>> need Primary key on all feature to be selectable).
>>>> David
>>>> GordonL wrote:
>>>>> Hi David, did you ever solve this problem?
>>>>> I am having trouble that features drawn from VIEWS in Oracle are not
>>>>> selectable (FDO 4.3). This is true for both the Autodesk Oracle
>>> Provider
>>>>> AND the KING one..
>>>>> thanks
>>>>> gordon
>>>>> David Hequet wrote:
>>>>>> Hello,
>>>>>> About this case i'm using Autodesk Mapguide Enterprise 2008 with
>>>>>> Autodesk Spatial Oracle FDO.
>>>>>> One of the new feature is "using Oracle View"
>>>>>> I tried to use a view with geometry, it work, but features can't be
>>>>>> selectable! I make them selectable in Studio but they are not,
>>> either in
>>>>>> dwf or ajax viewer.
>>>>>> Is it the same with the Oracle King provider? Or anyone has an idea
>>> on
>>>>>> how make them selectable (really :p )
>>> View this message in context:
>>> http://n2.nabble.com/Oracle-FDO-and-View-tp1811392p2946000.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/Oracle-FDO-and-View-tp1811392p2946099.html
> http://n2.nabble.com/Oracle-FDO-and-View-tp1811392p2977086.html
View this message in context: http://n2.nabble.com/Oracle-FDO-and-View-tp1811392p2977153.html
