[mapguide-users] Tooltip on MapGuide Web API
gatopardo
luis.diosdado at dossoftware.com
Wed May 27 02:37:27 EDT 2009
I've tried to open the map with MgMap.Create() and with MgMap.Open()
I've tried to call Save(), but doesnt' work.
It could be a bug? Or I am doing something wrong?
Chris Claydon wrote:
> I *think* that when you call RenderMap, it will set the width and height
> for the in-memory map object. Try calling Save() on the map to save the
> values back to the session repository before making the calls to
> GetDisplayWidth/GetDisplayHeight.
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of gatopardo
> Sent: Tuesday, May 26, 2009 7:05 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Tooltip on MapGuide Web API
> I've tried QueryFeatures on MgRenderingService, but it throws an
> exception.
> I've been looking the MgRenderingService source code, and the exception is
> because the map has the height, width and scale equal to 0.
> I don't know how can I set this values on Web Api. Because the map doesn't
> have setDisplayWidth or setDisplayHeight methods, only have
> GetDisplayWidth
> and GetDisplayHeight. Both returns 0.
> First of all I have rendered map images, but the map object doesn't save
> the
> render height and width.
> So I think the real problem is how to make that the MgMap Object
> "remembers"
> the last render height and width parameters, or how to set them.
>> I'm pretty sure that QUERYMAPFEATURES ends up calling the QueryFeatures
>> method on the MgRenderingService. You'll need to create a geometry object
>> that corresponds to the point you're clicking on. It is best to make it a
>> small square rather than a single point, in order for the spatial filter
>> to pick up the underlying feature. And it should use coordinates in the
>> same coordinate system as the map (not image pixel cords).
>> Chris.
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
>> Skovhede, GEOGRAF A/S
>> Sent: Monday, May 25, 2009 7:35 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Tooltip on MapGuide Web API
>> The operation is called "QUERYMAPFEATURES", but I can't seem
>> to find it as a function from the Web API.
>> You can see it in use if you look in the file:
>> C:\program
>> files\MapGuideOpenSource2.0\WebServerExtensions\www\viewerfiles\ajaxmappane.templ
>> line 2555.
>> You may also want to read this thread:
>> http://lists.osgeo.org/pipermail/mapguide-users/2007-January/004818.html
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> gatopardo skrev:
>> Nobody can help me?
>> gatopardo wrote:
>> How could I get the Tooltip on a point using MapGuide Web API?
>> Example:
>> I have generated an image using MgRenderingService.RenderMap, and after
>> that I want to get the tooltip on a point of this image, using the
>> coordinates on image pixels or converting them to lat-lon.
>> But I haven't found any method that makes this.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Tooltip-on-MapGuide-Web-API-tp2732016p2974565.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Tooltip-on-MapGuide-Web-API-tp2732016p2979358.html
