[mapguide-users] Tooltip on MapGuide Web API
gatopardo luis.diosdado at dossoftware.com
Wed May 27 03:20:22 EDT 2009
USING OPEN METHOD
mapGuideMap = new MgMap(this.mapGuideSiteCnn);
mapGuideMap.Open(this.MapGuideResourceService,mapResourceIdentifier);
//render map
byteReader = mapGuideRenderingService.RenderMap(mapGuideMap, selection,
mgEnvelope, width, height, new MgColor(backColor), "PNG", true);
mapGuideMap.Save(mapGuideResourceService);
//this doesn't throw any exception, but GetDisplayHeight/GetDisplayWidth
returns 0
//If i use this other overload
mapGuideMap.Save(mapGuideResourceService,new
MgResourceIdentifier(resourceId));
//this throws "An exception occurred in the XML parser" exception
USING CREATE METHOD
mapGuideMap.Create(mapGuideResourceService, mapResourceIdentifier,
"testMap");
//render map
//this throws "Null reference" exception
Jackie Ng wrote:
> Which constructor for MgMap did you use and which overload of
> Create()/Open()/Save() did you use?
> - Jackie
> gatopardo wrote:
>> I've tried to open the map with MgMap.Create() and with MgMap.Open()
>> I've tried to call Save(), but doesnt' work.
>> It could be a bug? Or I am doing something wrong?
>> Chris Claydon wrote:
>>> I *think* that when you call RenderMap, it will set the width and height
>>> for the in-memory map object. Try calling Save() on the map to save the
>>> values back to the session repository before making the calls to
>>> GetDisplayWidth/GetDisplayHeight.
>>> Chris.
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of gatopardo
>>> Sent: Tuesday, May 26, 2009 7:05 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: RE: [mapguide-users] Tooltip on MapGuide Web API
>>> I've tried QueryFeatures on MgRenderingService, but it throws an
>>> exception.
>>> I've been looking the MgRenderingService source code, and the exception
>>> is
>>> because the map has the height, width and scale equal to 0.
>>> I don't know how can I set this values on Web Api. Because the map
>>> doesn't
>>> have setDisplayWidth or setDisplayHeight methods, only have
>>> GetDisplayWidth
>>> and GetDisplayHeight. Both returns 0.
>>> First of all I have rendered map images, but the map object doesn't save
>>> the
>>> render height and width.
>>> So I think the real problem is how to make that the MgMap Object
>>> "remembers"
>>> the last render height and width parameters, or how to set them.
>>>> I'm pretty sure that QUERYMAPFEATURES ends up calling the QueryFeatures
>>>> method on the MgRenderingService. You'll need to create a geometry
>>>> object
>>>> that corresponds to the point you're clicking on. It is best to make it
>>>> a
>>>> small square rather than a single point, in order for the spatial
>>>> filter
>>>> to pick up the underlying feature. And it should use coordinates in the
>>>> same coordinate system as the map (not image pixel cords).
>>>> Chris.
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
>>>> Skovhede, GEOGRAF A/S
>>>> Sent: Monday, May 25, 2009 7:35 AM
>>>> To: MapGuide Users Mail List
>>>> Subject: Re: [mapguide-users] Tooltip on MapGuide Web API
>>>> The operation is called "QUERYMAPFEATURES", but I can't seem
>>>> to find it as a function from the Web API.
>>>> You can see it in use if you look in the file:
>>>> C:\program
>>>> files\MapGuideOpenSource2.0\WebServerExtensions\www\viewerfiles\ajaxmappane.templ
>>>> line 2555.
>>>> You may also want to read this thread:
>>>> http://lists.osgeo.org/pipermail/mapguide-users/2007-January/004818.html
>>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>>> gatopardo skrev:
>>>> Nobody can help me?
>>>> gatopardo wrote:
>>>> How could I get the Tooltip on a point using MapGuide Web API?
>>>> Example:
>>>> I have generated an image using MgRenderingService.RenderMap, and after
>>>> that I want to get the tooltip on a point of this image, using the
>>>> coordinates on image pixels or converting them to lat-lon.
>>>> But I haven't found any method that makes this.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>>> http://n2.nabble.com/Tooltip-on-MapGuide-Web-API-tp2732016p2974565.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Tooltip-on-MapGuide-Web-API-tp2732016p2979489.html
