[mapguide-users] MapGuide Open Source 2.1 beta -- Installer Problem
James Card James.Card at calcad.com
Wed May 27 13:53:34 EDT 2009
After uninstalling MGOS 2.0.2 the 2.1.0 installer ran successfully.
However, the PHP install is FUBAR: the IIS application mapping for PHP was
pointing to an old MGOS 1.2 directory, and loading any PHP page in the
browser (including just phpinfo()) returns "The specified module could not
be found.", even with "display_errors = On" in the php.ini file.
Running the newly installed "PHP,exe --version" from the command prompt
produces this:
   php.exe - Entry Point Not Found
   The procedure entry point GetModuleHandleExW could not be located in the
   dynamic link library KERNEL32.dll.
and
   PHP Warning:  PHP Startup: Unable to load dynamic library
   'C:\Program
Files\OSGeo\MapGuide\Web\Php\ext\php_MapGuideApiEnvConfig.dll'
    - The specified procedure could not be found.
    in Unknown on line 0
   PHP 5.2.5 (cli) (built: Nov  8 2007 23:18:51)
   Copyright (c) 1997-2007 The PHP Group
   Zend Engine v2.2.0, Copyright (c) 1998-2007 Zend Technologies
The file it is complaining about is located exactly where it is looking
for it.
Looks like it is time to do some housecleaning on that server. I'm going
to uninstall MGOS 2.1.0 and remove any references to MGOS or PHP from the
filesystem, registry and IIS metabase, then we'll try again.
James Card
California CAD Solutions, Inc.
209-578-5580 - Voice
209-521-6493 - FAX
On Tue, 26 May 2009 17:06:14 -0700, Jason Birch <Jason.Birch at nanaimo.ca>
wrote:
> James, you can extract the MSI and VS redist from the .exe file using
> 7Zip, and then (after installing the redist) run it with syntax like:
> msiexec /i PackageName.msi /l*v logfile.log
> I don't think the bootstrapper we're using has the ability to generate
> logfiles automatically.  It was something we wanted, but didn't have the
> ability to tackle for this release.
> I'd be interested in knowing which action is failing.  It's a tough call
> between allowing the install to succeed but be incomplete, or rolling
> back on IIS configuration errors.
> Jason
> -----Original Message-----
> From: James Card
> Sent: Tuesday, May 26, 2009 4:18 PM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] MapGuide Open Source 2.1 beta -- Installer
> Problem
> I'm trying to upgrade our MGOS 2.0.2 installation on Window 2000 server.
> The new installer runs through the "copying new files" stage, but then
> encounters an error during the IIS metabase transaction, aborts the
> install, and rolls back all the installer's actions. I cannot find the
> MSI
> log files (except for the VCRedist prerequisite) so I can't figure out
> exactly what is failing.
> I'll try uninstalling MGOS 2.0.2 and clearing any remnants of that
> install
>  from the IIS metabase, and then reinstall 2.1.0.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
