[mapguide-users] Add Data Connection for Shp's Problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu May 28 02:43:12 EDT 2009
You need to upload more than just the .shp file.
There are usually a bunch of files related to a single shape file,
and you need to upload them all (they all have the same filename, but
different extensions).
The Maestro UI was not really helpfull there, so I changed it.
You can either use your current version of Maestro, and add the files
manually,
or use the newest preview version and it will ask you if you want it
done automatically.
(new version released a few hours ago r3911):
http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
Regards, Kenneth Skovhede, GEOGRAF A/S
Tom Lazo skrev:
> Hi all,
> Well, i've tried to "Upload Data into a new Feature Source" via mapguide,
> but the link throws me to a "Not found" page. Ok... i've realized this
> problems some weeks before.. so i got the AutoDesk MapGuide Studio
> 2009...trial.. ok. Actually this frameworks allows me to upload the data
> from a shape file.
> Ok, now i'm trying to do the same but with Maestro, so i go to
> file->new->Data Connection->OSGeo FDO Provider for SHP... then i search my
> shape file and open it.
> Now, i validate this resource whith the big green check and i get this
> error:
> Validating file:
> Session:08df1c68-2d35-102c-8000-001cc0a62e16_es_7F0000010AFC0AFB0AFA//6d899f62-7b06-4fb3-8f53-d8e9b2187049.FeatureSource
> Error - OSGeo.MapGuide.MaestroAPI.FeatureSource: Failed to read schema
> description: Error en el servidor remoto: (559)
> MgInvalidStreamHeaderException.:
> Invalid stream header exception.
> Exception occurred in method MgCommand.GetResponse at line 152 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\Services/Command.cpp
> Plz, tell what's the cause of this mistake...i'm really lost.
> Thanks
> Tom
