[mapguide-users] ECWs and MG 2.1
Danfri
danfrias at gmail.com
Fri May 29 14:21:53 EDT 2009
Jason/Chris:
First of all I want to thank you for the prompt responses. Unfortunately,
after struggling with MapGuide all day yesterday, I have still been
unsuccessful in my attempts to display ECW files in 2.1. To summarize what
I did:
1) I do have my imagery in an alias folder and I did it reestablish this
folder after installing 2.1 then restarted the service. If I create a data
connection from this alias folder using JPG and JGW files, it works fine.
It is with ECW files that it fails. As a simple test, I go into Maestro,
create a data connection pointing to a folder containing JPGs and JGWs, and
then if I click the "Preview this item" button. I then get a webpage which
will allow me to see a list of all the JPG files it has recognized. If I do
this with ECWs on 2.0.2 it works the same way, but with 2.1 it returns an
empty list every time and does not display those ECWs on a map.
2) I have placed the files contained within the gdal_wavelet_3.4.zip file
into my MapGuide installation in the appropriate bin and fdo directories.
3) I downloaded the ECW Support DLLs and copied in the four NCSxxx.dll files
into the fdo directory of the MapGuide installation and then restarted the
service.
At this point I am still unable to display ECW files on the map and, in
fact, as I mentioned in (1) Maestro does not recognize ECWs as a valid data
source through the "Preview this item" function (though this works for JPGs
and worked for ECWs in 2.0.2). I have even gone so far as to completely
remove my installation of 2.1, deleting the directories and files left
behind, then completely reinstalling from scratch, but to no avail.
I would greatly appreciate any more ideas anyone might have and would like
to know if anyone has of yet been able to get ECWs to display through
MapGuide 2.1.
View this message in context: http://n2.nabble.com/ECWs-and-MG-2.1-tp2978248p2995276.html
