[mapguide-users] mapguide trouble installing ubuntu
Remco Houtkamp
r.houtkamp at burohoutkamp.nl
Mon Nov 2 05:36:40 EST 2009
Hi, after a lot of trouble with windows, fdo and postgis I'm trying a setup with ubuntu. I just don't know that much about linux so I'm just following the how-to' s.
After I enter the sudo ./build_oem.sh command I see a lot text within terminal (installing?) but it stops at a certain point and gives me the following error (some of it is dutch):
config.status: error: cannot find input file: `Makefile.in'
make: *** Geen doelen opgegeven en geen makefile gevonden. Gestopt.
DWFCORE 1.0: Error build failed (0).................
remco at ubuntu:/usr/local/mapguideopensource$ gcc
gcc: no input files
remco at ubuntu:/usr/local/mapguideopensource$ aclocal
configure.in:18: warning: macro `AM_PROG_LIBTOOL' not found in library
autom4te: cannot create autom4te.cache: Bestand of map bestaat niet
aclocal: autom4te failed with exit status: 1
remco at ubuntu:/usr/local/mapguideopensource$ sudo ./build_oem.sh
MapGuide Open Source build script for OEM components
OEM Build Initialization ............................
Oem Libraries will be installed at: /usr/local/mapguideopensource
./build_oem.sh: 595: pushd: not found
ace: Initialization...........................
ace: Configure/Build ...........................
./build_oem.sh: 610: pushd: not found
ACE 5.4: Error build failed (0).................
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091102/0e2b536d/attachment.bin
