[mapguide-users] Creating and adding layers
Dejan Gregor dejan.gregor at gmail.com
Wed Nov 4 03:05:22 EST 2009
I would like to add a question -- is it possible to programmatically add new
layers into the 'map' triggering a command from the MapGuide web client?
It is an actual configuration change of the 'map' that is not done in
Mapguide Mestro.
Dejan
On Wed, Nov 4, 2009 at 08:39, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk>wrote:
> There is a short (incomplete) guide here that explains the procedure from a
> users viewpoint:
> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
> If you have MapGuide Enterprise, you can get Studio for free, which has a
> manual in the "Help" menu.
> If you need to create data as well, you need a GIS client application, such
> as Autocad Map, ArcGIS or MapInfo.
> (There are free clients avalible as well)
> Your question is a bit vague, so if this is an answer to another question,
> can you explain your current setup?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> oshan skrev:
>  Hi
>> I want to know how to create layers?
>> Say that you have a map and you want to create layers for political
>> divisions. How would you go about doing this?
>> I ask this before but I didn't get any answer. My apologies if its a
>> stupic
>> question! Since I don't really have any good vectored based maps, is it
>> possible to use a jpeg as a base image? How do I achieve this?
>> I appreciate any help
>> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091104/5ead1e5a/attachment.html
