[mapguide-users] information is displayed on a pop-up window
    Kenneth Skovhede, GEOGRAF A/S
    ks at geograf.dk
    Wed Nov  4 09:57:45 EST 2009
That is not directly supported.
You can make a link like this (in Maestro):
javascript:window.open('http://www.google.com');
An alternative version is to create a html page that parses the
querystring and opens the supplied link, like:
<html>
<body onload="activate_popup();">
<script>
function activate_popup() {
  var url = document.location.href; //Get full url
  url = url.substring(url.indexOf("?url=") + "?url=".length); //Strip
until ?url=
  url = decodeURIComponent(url); //Fix up any browser url mangling
  window.open(url); //Add options here
</script>
</body>
</html>
Save the html as popup.html.
Then make a hidden frame as the target, and place an url like this (in
Maestro):
popup.html?url=http://www.google.com
Beware that most browsers will block popups that are activated with the
"window.open" call.
Regards, Kenneth Skovhede, GEOGRAF A/S
NISHA P skrev:
> Hi Kenneth
> I did this also..But in "New window",the location of the file is shown
> in the address bar...So that I want to display the  details on a
> pop up window...But I don't know in which file i have  to  write the
> script for pop-up window..
> On Wed, Nov 4, 2009 at 3:30 PM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk <mailto:ks at geograf.dk>> wrote:
>     In your WebLayout there is an option that states "Linktarget" or
>     "Links open in".
>     Select either "New window" or "Specified frame" and write "_blank"
>     as the frame (without quotes).
>     NISHA P skrev:
>>     Hi All
>>     I have a point layer in my map..when i click a point on the
>>     map,the information will got in the right side of the map(taskpane)..
>>     I want to display the information on a pop-up window..For this,
>>     in which file I have to write the code for pop-up?
>>     I am using mapguide open and maestro with php and ajaxviewer..
>>     Thanks and regards
>>     Nisha
>>     _______________________________________________
>>     mapguide-users mailing list
>>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Nisha
> nisha at iiitmk.ac.in <mailto:nisha at iiitmk.ac.in>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091104/c65fe49a/attachment.html
