[mapguide-users] Creating and adding layers
oshan icycool at inbox.com
Wed Nov 4 21:53:13 EST 2009
Hi Kenneth
Thanks for you reply. I'm basically trying to get a map displayed in the
ajax viewer and the map I'm planning to use is a raster image.
I tried doing it using map guide maestro but I couldn't get the image
displayed. I tnk its something to do with the coordinate system may be its
way off the screen.
I was looking at GDAL and found this link. It kind shows how to add
coordinate to raster image. I'll try that and see if it works.
http://trac.osgeo.org/gdal/wiki/UserDocs/RasterProcTutorial
By the way do you mean data files like .shp? what is a good free client I
used to create such data?
Thanks
Kenneth Skovhede, GEOGRAF A/S wrote:
> There is a short (incomplete) guide here that explains the procedure
> from a users viewpoint:
> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
> If you have MapGuide Enterprise, you can get Studio for free, which has
> a manual in the "Help" menu.
> If you need to create data as well, you need a GIS client application,
> such as Autocad Map, ArcGIS or MapInfo.
> (There are free clients avalible as well)
> Your question is a bit vague, so if this is an answer to another
> question, can you explain your current setup?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> oshan skrev:
>> Hi
>> I want to know how to create layers?
>> Say that you have a map and you want to create layers for political
>> divisions. How would you go about doing this?
>> I ask this before but I didn't get any answer. My apologies if its a
>> stupic
>> question! Since I don't really have any good vectored based maps, is it
>> possible to use a jpeg as a base image? How do I achieve this?
>> I appreciate any help
>> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Creating-and-adding-layers-tp3941863p3949895.html
