[mapguide-users] Add geometry to SHP
sekko970 fabio.franceschini at techneteam.it
Thu Nov 5 12:08:57 EST 2009
I tryng to add a point to an existing SHP data connection in ASP.Net
application, using MG API.
Dim dataSource as String = "Library://.../MySHP.FeatureSource"
Dim dataSourceId As New MgResourceIdentifier(dataSource)
Dim MyProps As New MgPropertyCollection()
Dim agfRW As New MgAgfReaderWriter()
Dim geomFactory As New MgGeometryFactory
Dim myPoint As MgPoint =
geomFactory.CreatePoint(geomFactory.CreateCoordinateXY(X, Y))
'ID
Dim IDProp As New MgInt32Property("FeatID", IDValue)
MyProps.Add(IDProp)
'MyProp
Dim MyProp As New MgDoubleProperty("MyProp", MyPropValue)
MyProps.Add(MyProp)
'Geometry
Dim geomReader As MgByteReader = agfRW.Write(myPoint)
Dim geometryProp As New MgGeometryProperty("Geometry", geomReader)
MyProps.Add(geometryProp)
Dim propCollection As New MgBatchPropertyCollection()
propCollection.Add(MyProps)
Dim commands As New MgFeatureCommandCollection()
commands.Add(New MgInsertFeatures(MyFeatureName, propCollection))
Dim res As MgPropertyCollection = featureSrvc.UpdateFeatures(dataSourceId,
commands, False)
ReleaseReader(res, commands)
In ReleaseReader, I have the following error:
Unable to cast object of type 'OSGeo.MapGuide.MgStringProperty' to type
'OSGeo.MapGuide.MgFeatureProperty'.
In fact, res has only one property of type MgStringProperty: but why?
Have you any idea where is the error?
Thanks, Fabio
View this message in context: http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3953583.html
