[mapguide-users] Creating and adding layers
oshan icycool at inbox.com
Fri Nov 6 00:32:32 EST 2009
Hi Kenneth
I managed to get a student version of ArcGIS. I created a tiff and a world
file after using some PNG map images. I placed the two generated files into
a single folder and imported it using maestro. After defining the layers and
map and setting up the extent I was able to preview it on mapguide.
I looked in the FdoGdalNotes for the plugin
(http://home.gdal.org/dl/gdal14_vc8/) but the links doesn't work. In any
case I'm able to view the images so maybe all the plugins are in place in my
installation!
I wanted to add a layer on top of this map (by the way this a map of
Queensland, Australia). This new layer is going to be some rural region
within the state. I cut out this region from the original map (base map) and
created a separate image with just that rural area surrounded with
transparent background so that if I superimpose them it will appear at the
right location on the base map. I created a new layer for this image using
the same procedure I describe before. Only problem is the tiff format didn't
recognise transparency and made the background white. So when I place the
small region above the state only thing I can see is that!
So now I'm wondering...: if my application is not going to handle any
geospatial vector data, am I making it harder for my self by using MG os?? I
mean I would be able to use normal HTML,css,js, and jsp to do this. I could
use the z index in css to put bunch of images together and use js to turn
them on and off. But of course I will have to do the zooming, paning,
context menus, toolbars etc from scratch so I don't know if I will hit the
brick wall somewhere down the track!
Kenneth Skovhede, GEOGRAF A/S wrote:
> Rasters are notoriously difficult to get to work.
> First of, you need to run the server from the console with the
> CPL_DEBUG=on:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> (See at the bottom of the page).
> And you have to create the gdalplugin folder yourself, so you get the
> file layout
> as described on FdoGdalNotes page.
> Your MapDefinition coordinate system and raster coordinate system MUST
> match 100%.
> Also look in the error log file:
> C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
> For a free vector editor, try Kosmo GIS:
> http://www.opengis.es/
> Good luck!
> Regards, Kenneth Skovhede, GEOGRAF A/S
> oshan skrev:
>> By the way I'm using mapguide os 2.0 with jsp extension. does this come
>> with
>> the GDAL plugin to handle all the raster data? I checked in my bin folder
>> and there is no gdalplugins folder! But inside FDO I have a file called
>> gdal14.dll. If this is not enough where do I get this full plugin from
>> and
>> which version. The version of the gdal14.dll is 1.4.3.0
>> cheers
>> oshan wrote:
>>> Hi Kenneth
>>> Thanks for you reply. I'm basically trying to get a map displayed in the
>>> ajax viewer and the map I'm planning to use is a raster image.
>>> I tried doing it using map guide maestro but I couldn't get the image
>>> displayed. I tnk its something to do with the coordinate system may be
>>> its
>>> way off the screen.
>>> I was looking at GDAL and found this link. It kind shows how to add
>>> coordinate to raster image. I'll try that and see if it works.
>>> http://trac.osgeo.org/gdal/wiki/UserDocs/RasterProcTutorial
>>> By the way do you mean data files like .shp? what is a good free client
>>> I
>>> used to create such data?
>>> Thanks
>>>> There is a short (incomplete) guide here that explains the procedure
>>>> from a users viewpoint:
>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
>>>> If you have MapGuide Enterprise, you can get Studio for free, which has
>>>> a manual in the "Help" menu.
>>>> If you need to create data as well, you need a GIS client application,
>>>> such as Autocad Map, ArcGIS or MapInfo.
>>>> (There are free clients avalible as well)
>>>> Your question is a bit vague, so if this is an answer to another
>>>> question, can you explain your current setup?
>>>> oshan skrev:
>>>>> Hi
>>>>> I want to know how to create layers?
>>>>> Say that you have a map and you want to create layers for political
>>>>> divisions. How would you go about doing this?
>>>>> I ask this before but I didn't get any answer. My apologies if its a
>>>>> stupic
>>>>> question! Since I don't really have any good vectored based maps, is
>>>>> it
>>>>> possible to use a jpeg as a base image? How do I achieve this?
>>>>> I appreciate any help
>>>>> Thanks
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Creating-and-adding-layers-tp3941863p3957015.html
