[mapguide-users] Add geometry to SHP
sekko970
fabio.franceschini at techneteam.it
Fri Nov 6 03:41:34 EST 2009
Hi Simon,
what I have to do to include in my ASP.NET project FDO .NET API?
Simon Pelicon wrote:
> Hi!
> Here is sample in C# from my code using just FDO .NET API.
> This inserts FEATURE in any FDO datasource specified in my FDO connection
> (m_Conn) like SHP,SDF, oracle ....
> IInsert command =
> (IInsert)m_base.m_Conn.CreateCommand(CommandType.CommandType_Insert);
> FgfGeometryFactory factory = new FgfGeometryFactory();
> IDirectPosition position = factory.CreatePositionXYZ(X,Y, 0.0);
> IPoint point = factory.CreatePoint(position);
> command .PropertyValues.Add(new PropertyValue(GEOMETRY_COLUMN, new
> GeometryValue(factory.GetFgf(point))));
> command .PropertyValues.Add(new PropertyValue(LAYER_COLUMN, new
> StringValue(bref.Layer)));
> command .PropertyValues.Add(new PropertyValue(BLOCK_COLUMN, new
> StringValue(bref.Name)));
> reader = command.Execute();
> if (reader.ReadNext())
> Simon
> On Fri, Nov 6, 2009 at 8:27 AM, Dejan Gregor <dejan.gregor at gmail.com>
> wrote:
>> Dear Fabio,
>> you are saying that with the exsiting FDO it is possible to add geometry
>> to
>> a SHP?
>> Do you have a sample code for MGOS 2.x also for the interface or maybe a
>> whole project/sln? I am not a programmer, but would like just to test
>> this
>> functionality in MapGuide.
>> Best regards,
>> Dejan
>> On Fri, Nov 6, 2009 at 00:29, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>> what's in the string? it's probably an error string
>>> if your feature source readonly?
>>> http://trac.osgeo.org/mapguide/ticket/649
>>> a very nasty annoying bug
>>> z
>>> On Fri, Nov 6, 2009 at 9:45 AM, Jackie Ng <jumpinjackie at gmail.com>
>>> wrote:
>>> > What does your ReleaseReader() look like?
>>> > If it's from the samples, it's supposed to close any open
>>> MgFeatureReaders
>>> > that may exist in the result returned from
>>> MgFeatureService.UpdateFeatures()
>>> > - Jackie
>>> > sekko970 wrote:
>>> >> I tryng to add a point to an existing SHP data connection in ASP.Net
>>> >> application, using MG API.
>>> >> Dim dataSource as String = "Library://.../MySHP.FeatureSource"
>>> >> Dim dataSourceId As New MgResourceIdentifier(dataSource)
>>> >> Dim MyProps As New MgPropertyCollection()
>>> >> Dim agfRW As New MgAgfReaderWriter()
>>> >> Dim geomFactory As New MgGeometryFactory
>>> >> Dim myPoint As MgPoint =
>>> >> geomFactory.CreatePoint(geomFactory.CreateCoordinateXY(X, Y))
>>> >> 'ID
>>> >> Dim IDProp As New MgInt32Property("FeatID", IDValue)
>>> >> MyProps.Add(IDProp)
>>> >> 'MyProp
>>> >> Dim MyProp As New MgDoubleProperty("MyProp", MyPropValue)
>>> >> MyProps.Add(MyProp)
>>> >> 'Geometry
>>> >> Dim geomReader As MgByteReader = agfRW.Write(myPoint)
>>> >> Dim geometryProp As New MgGeometryProperty("Geometry", geomReader)
>>> >> MyProps.Add(geometryProp)
>>> >> Dim propCollection As New MgBatchPropertyCollection()
>>> >> propCollection.Add(MyProps)
>>> >> Dim commands As New MgFeatureCommandCollection()
>>> >> commands.Add(New MgInsertFeatures(MyFeatureName, propCollection))
>>> >> Dim res As MgPropertyCollection =
>>> featureSrvc.UpdateFeatures(dataSourceId,
>>> >> commands, False)
>>> >> ReleaseReader(res, commands)
>>> >> In ReleaseReader, I have the following error:
>>> >> Unable to cast object of type 'OSGeo.MapGuide.MgStringProperty' to
>>> type
>>> >> 'OSGeo.MapGuide.MgFeatureProperty'.
>>> >> In fact, res has only one property of type MgStringProperty: but why?
>>> >> Have you any idea where is the error?
>>> >> Thanks, Fabio
>>> > View this message in context:
>>> http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3955574.html
>>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> > _______________________________________________
>>> > mapguide-users mailing list
>>> > mapguide-users at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
View this message in context: http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3957522.html
