[mapguide-users] Add geometry to SHP
sekko970
fabio.franceschini at techneteam.it
Fri Nov 6 05:20:39 EST 2009
The problem is that I cannot include FDOSpatial.dll in my project.
In fact, if I try to create a reference to OSGeo.FDO.Spatial.dll, I have the
following error:
no type libraries were found in the component
(FDOSpatial.dll is already in my project bin folder).
f.
sekko970 wrote:
> I have already downloaded all the dll for FDO Windows SDK, but 3.4
> version.
> f.
> Simon Pelicon wrote:
>> You have all this files (also OSGeo.FDO.Spatial.dll ) in FDO Windows
>> SDK.
>> download link:
>> http://fdo.osgeo.org/content/fdo-331-downloads
>> <http://fdo.osgeo.org/content/fdo-331-downloads>simon
>> On Fri, Nov 6, 2009 at 10:58 AM, sekko970
>> <fabio.franceschini at techneteam.it>wrote:
>>> Ok for
>>> OSGeo.FDO.dll
>>> OSGeo.FDO.Geometry.dll
>>> OSGeo.FDO.Common.dll
>>> but if I try to create a reference to OSGeo.FDO.Spatial.dll, I have the
>>> following error:
>>> no type libraries were found in the component.
>>> f.
>>> > Hi!
>>> > Add references to this files:
>>> > OSGeo.FDO.dll
>>> > simon
>>> > On Fri, Nov 6, 2009 at 9:41 AM, sekko970
>>> >> Hi Simon,
>>> >> what I have to do to include in my ASP.NET project FDO .NET API?
>>> >> > Hi!
>>> >> > Here is sample in C# from my code using just FDO .NET API.
>>> >> > This inserts FEATURE in any FDO datasource specified in my FDO
>>> >> connection
>>> >> > (m_Conn) like SHP,SDF, oracle ....
>>> >> > IInsert command =
>>> (IInsert)m_base.m_Conn.CreateCommand(CommandType.CommandType_Insert);
>>> >> > FgfGeometryFactory factory = new FgfGeometryFactory();
>>> >> > IDirectPosition position = factory.CreatePositionXYZ(X,Y, 0.0);
>>> >> > IPoint point = factory.CreatePoint(position);
>>> >> > command .PropertyValues.Add(new PropertyValue(GEOMETRY_COLUMN, new
>>> >> > GeometryValue(factory.GetFgf(point))));
>>> >> > command .PropertyValues.Add(new PropertyValue(LAYER_COLUMN, new
>>> >> > StringValue(bref.Layer)));
>>> >> > command .PropertyValues.Add(new PropertyValue(BLOCK_COLUMN, new
>>> >> > StringValue(bref.Name)));
>>> >> > reader = command.Execute();
>>> >> > if (reader.ReadNext())
>>> >> > Simon
>>> >> > On Fri, Nov 6, 2009 at 8:27 AM, Dejan Gregor
>>> <dejan.gregor at gmail.com>
>>> >> > wrote:
>>> >> >> Dear Fabio,
>>> >> >> you are saying that with the exsiting FDO it is possible to add
>>> >> geometry
>>> >> >> to
>>> >> >> a SHP?
>>> >> >> Do you have a sample code for MGOS 2.x also for the interface or
>>> maybe
>>> >> a
>>> >> >> whole project/sln? I am not a programmer, but would like just to
>>> test
>>> >> >> this
>>> >> >> functionality in MapGuide.
>>> >> >> Best regards,
>>> >> >> Dejan
>>> >> >> On Fri, Nov 6, 2009 at 00:29, Zac Spitzer <zac.spitzer at gmail.com>
>>> >> wrote:
>>> >> >>> what's in the string? it's probably an error string
>>> >> >>> if your feature source readonly?
>>> >> >>> http://trac.osgeo.org/mapguide/ticket/649
>>> >> >>> a very nasty annoying bug
>>> >> >>> z
>>> >> >>> On Fri, Nov 6, 2009 at 9:45 AM, Jackie Ng
>>> <jumpinjackie at gmail.com>
>>> >> >>> wrote:
>>> >> >>> > What does your ReleaseReader() look like?
>>> >> >>> > If it's from the samples, it's supposed to close any open
>>> >> >>> MgFeatureReaders
>>> >> >>> > that may exist in the result returned from
>>> >> >>> MgFeatureService.UpdateFeatures()
>>> >> >>> > - Jackie
>>> >> >>> > sekko970 wrote:
>>> >> >>> >> I tryng to add a point to an existing SHP data connection in
>>> >> ASP.Net
>>> >> >>> >> application, using MG API.
>>> >> >>> >> Dim dataSource as String = "Library://.../MySHP.FeatureSource"
>>> >> >>> >> Dim dataSourceId As New MgResourceIdentifier(dataSource)
>>> >> >>> >> Dim MyProps As New MgPropertyCollection()
>>> >> >>> >> Dim agfRW As New MgAgfReaderWriter()
>>> >> >>> >> Dim geomFactory As New MgGeometryFactory
>>> >> >>> >> Dim myPoint As MgPoint =
>>> >> >>> >> geomFactory.CreatePoint(geomFactory.CreateCoordinateXY(X, Y))
>>> >> >>> >> 'ID
>>> >> >>> >> Dim IDProp As New MgInt32Property("FeatID", IDValue)
>>> >> >>> >> MyProps.Add(IDProp)
>>> >> >>> >> 'MyProp
>>> >> >>> >> Dim MyProp As New MgDoubleProperty("MyProp", MyPropValue)
>>> >> >>> >> MyProps.Add(MyProp)
>>> >> >>> >> 'Geometry
>>> >> >>> >> Dim geomReader As MgByteReader = agfRW.Write(myPoint)
>>> >> >>> >> Dim geometryProp As New MgGeometryProperty("Geometry",
>>> geomReader)
>>> >> >>> >> MyProps.Add(geometryProp)
>>> >> >>> >> Dim propCollection As New MgBatchPropertyCollection()
>>> >> >>> >> propCollection.Add(MyProps)
>>> >> >>> >> Dim commands As New MgFeatureCommandCollection()
>>> >> >>> >> commands.Add(New MgInsertFeatures(MyFeatureName,
>>> propCollection))
>>> >> >>> >> Dim res As MgPropertyCollection =
>>> >> >>> featureSrvc.UpdateFeatures(dataSourceId,
>>> >> >>> >> commands, False)
>>> >> >>> >> ReleaseReader(res, commands)
>>> >> >>> >> In ReleaseReader, I have the following error:
>>> >> >>> >> Unable to cast object of type
>>> 'OSGeo.MapGuide.MgStringProperty'
>>> to
>>> >> >>> type
>>> >> >>> >> 'OSGeo.MapGuide.MgFeatureProperty'.
>>> >> >>> >> In fact, res has only one property of type MgStringProperty:
>>> but
>>> >> why?
>>> >> >>> >> Have you any idea where is the error?
>>> >> >>> >> Thanks, Fabio
>>> >> >>> > View this message in context:
>>> >> >>> http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3955574.html
>>> >> >>> > Sent from the MapGuide Users mailing list archive at
>>> Nabble.com.
>>> >> >>> > _______________________________________________
>>> >> >>> > mapguide-users mailing list
>>> >> >>> > mapguide-users at lists.osgeo.org
>>> >> >>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> >> >>> Zac Spitzer
>>> >> >>> Solution Architect / Director
>>> >> >>> Ennoble Consultancy Australia
>>> >> >>> http://www.ennoble.com.au
>>> >> >>> http://zacster.blogspot.com
>>> >> >>> +61 405 847 168
>>> >> http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3957522.html
>>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3957821.html
View this message in context: http://n2.nabble.com/Add-geometry-to-SHP-tp3953583p3957890.html
