[mapguide-users] Inser feature problem
Zac Spitzer zac.spitzer at gmail.com
Mon Nov 9 04:08:30 EST 2009
which version and edition of mapguide,
autodesk fdo or king/osgeo fdo provider?
z
On Mon, Nov 9, 2009 at 8:05 PM, mighty_duck <msiljegovic at gmail.com> wrote:
> FDO
> zspitzer wrote:
>> which provider are you using?
>> On Mon, Nov 9, 2009 at 8:01 PM, mighty_duck <msiljegovic at gmail.com> wrote:
>>> I dont think it is Oracle error, it inserts everything correcly to
>>> database,
>>> problem start when FeatureService wants to return "information" that
>>> feature
>>> is succesufully inserted into the database.
>>> Wouldn't it be maybe FDO problem?!
>>> thanks
>>> Dejan Gregor wrote:
>>>> What is the ORA error/exception number?
>>>> Dejan
>>>> On Mon, Nov 9, 2009 at 09:42, mighty_duck <msiljegovic at gmail.com> wrote:
>>>>> Hi,
>>>>> I created table in Oracle with two columns: ID(primary key) and
>>>>> Geometry(SDO_GEOMETRY). I also done all stuffs with metadata and
>>>>> spatial
>>>>> index.....
>>>>> Problem is when I want to insert feature into the table...
>>>>> featureService.UpdateFeatures(resourceIdentifier, commandCollection,
>>>>> false);. This command correctly inserts new feature into the table, but
>>>>> throws also exception depending if I specify ID directly (Feature
>>>>> service
>>>>> exception - error occurred while insert operation, no ID to retrieve),
>>>>> or
>>>>> I
>>>>> let Oracle autogenerates the new ID(An unclassified exception
>>>>> occurred).
>>>>> So in both cases feature is inserted into the table, but everytime I
>>>>> get
>>>>> exception, and I cant realize what cause this problem!!!
>>>>> thanks in advance
>>>>> View this message in context:
>>>>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971827.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://n2.nabble.com/Inser-feature-problem-tp3971827p3971881.html
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
> View this message in context: http://n2.nabble.com/Inser-feature-problem-tp3971827p3971901.html
Zac Spitzer
+61 405 847 168
