[mapguide-users] Problem with MrSid in Maestro(1.1) - Mapguide 2.1
Homan, Thomas
thoman at co.gila.az.us
Mon Nov 9 12:33:12 EST 2009
Have you tried taking the bounds to the actual bounding box of the
images and just not a huge generic bounds statement?
Also, does it work if there is only one image loaded?
What is the rest of the config.xml file? I found a helpful reference to
the config.xml file for MGE at
http://images.autodesk.com/apac_japan_main/files/linking_to_external_dat
a_autodeskmapguidewhitepaper.pdf when I was having problems with imagery
on my MGE2010 instal. I put the bounds higher up and let the images land
where they were rather than micromanaging. Everything worked better
after that.
Just some thoughts
Tom
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of HABC
Sent: Saturday, November 07, 2009 8:38 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Problem with MrSid in Maestro(1.1) - Mapguide
2.1
I have been trying to get the raster image to work but with no luck. I
have downloaded the plugin. I don't know what i have missed. Couple
things i
notice: when i try to save a raster dataconnect the message comes up
like this "Spatial context extent appeas to be invalid(or default)". I
did set up coord override. Other thing is in the config file has
something like this:
<Feature name="CA272">
<Band name="RGB" number="1">
<Image frame="1" name="CA272.sid">
<Bounds>
<MinX>-10000000</MinX>
<MinY>-10000000</MinY>
<MaxX>10000000</MaxX>
<MaxY>10000000</MaxY>
</Bounds>
</Image>
</Band>
</Feature>
<Feature name="CA273">
<Image frame="1" name="CA273.sid">
<Bounds>
</Bounds>
</Image>
</Band>
</Feature>
Please help!!
HABC
View this message in context:
http://n2.nabble.com/Problem-with-MrSid-in-Maestro-1-1-Mapguide-2-1-tp39
64578p3964578.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
