[mapguide-users] Problem with MrSid in Maestro(1.1) - Mapguide 2.1
Jason Birch jason at jasonbirch.com
Tue Nov 10 21:32:40 EST 2009
Have you tried that on a local drive?
I don't know how well / whether gdal works wth UNC shares. Also, is
your mapguide service running as an account that is a domain user and,
in this case, an administrator on the remote server since you're
trying to access an admin share?  You may want to try logging in as
that user, persistently mapping a drive letter, and using that
instead.
I can guarantee that unless there is a reproducible defect logged in
trac, that it is unlikely that your symptoms will be resolved in a
post-2.1 release.  Stuff just doesn't get fixed in open source
projects unless people are aware of it, and someone cares enough to do
something about it. We do benefit some from q/a and remediation on
mapguide core from the Autodesk team, but this halo does not usually
cascade through to the gdal raster provider.
Jason
On 2009-11-10, HABC <chiajhu at hotmail.com> wrote:
> Thanks for all the responses. I did try everything that i know/can find and
> I
> also tried to manually set up the config.xml but still with no luck. I hope
> this is just a bug and hopefully it will be fixed in the final 2.1 release.
> Here is config.xml i manually created.
> <?xml version="1.0" encoding="UTF-8"?>
> <fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:fdo="http://fdo.osgeo.org/schemas"
> xmlns:fds="http://fdo.osgeo.org/schemas/fds">
> <gml:DerivedCRS gml:id="coordSys">
> <gml:remarks>LL83</gml:remarks>
> <gml:srsName>LL83</gml:srsName>
> <gml:validArea>
> <gml:boundingBox>
> <gml:pos>1390000 556000</gml:pos>
> <gml:pos>1448000 623000</gml:pos>
> </gml:boundingBox>
> </gml:validArea>
> <gml:baseCRS>
> <fdo:WKTCRS gml:id="coordSys">
> <fdo:WKT>GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</fdo:WKT>
> </fdo:WKTCRS>
> </gml:baseCRS>
> <gml:definedByConversion
> xlink:href="http://fdo.osgeo.org/coord_conversions#identity"/>
> <gml:derivedCRSType
> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
> <gml:usesCS
> xlink:href="http://fdo.osgeo.org/cs#default_cartesian"/>
> </gml:DerivedCRS>
> <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
> targetNamespace="http://fdo.osgeo.org/schemas/feature/rasters"
> xmlns:rasters="http://fdo.osgeo.org/schemas/feature/rasters"
> elementFormDefault="qualified" attributeFormDefault="unqualified">
> <xs:element name="RasterType" type="rasters:RasterTypeType"
> abstract="false" substitutionGroup="gml:_Feature">
> <xs:key name="RasterTypeKey">
> <xs:selector xpath=".//RasterType"/>
> <xs:field xpath="Id"/>
> </xs:key>
> </xs:element>
> <xs:complexType name="RasterTypeType" abstract="false"
> fdo:hasGeometry="false">
> <xs:complexContent>
> <xs:extension base="gml:AbstractFeatureType">
> <xs:sequence>
> <xs:element name="Id">
> <xs:annotation>
> <xs:documentation/>
> </xs:annotation>
> <xs:simpleType>
> <xs:restriction base="xs:string">
> <xs:maxLength value="256"/>
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
> <xs:element name="Image" type="fdo:RasterPropertyType"
> fdo:defaultImageXSize="200" fdo:defaultImageYSize="200">
> <xs:annotation>
> <xs:appinfo source="http://fdo.osgeo.org/schemas">
> <fdo:DefaultDataModel dataModelType="Unknown"
> dataType="Unknown" organization="Row" bitsPerPixel="32" tileSizeX="128"
> tileSizeY="128"/>
> </xs:appinfo>
> </xs:annotation>
> </xs:element>
> </xs:sequence>
> </xs:extension>
> </xs:complexContent>
> </xs:complexType>
> </xs:schema>
> <SchemaMapping provider="OSGeo.Gdal" name="rasters"
> xmlns="http://fdogrfp.osgeo.org/schemas">
> <complexType name="RasterTypeType">
> <RasterDefinition name="rasters">
> <Location name="\\Atimagesvr\e$\GeoData\imagery\Sid\">
> <Feature name="BR264">
> <Band name="RGB" number="1">
> <Image name="BR264.sid" frame="1">
> <Bounds>
>                     <MinX>1393000</MinX>
>                     <MinY>621000</MinY>
>                     <MaxX>1396000</MaxX>
>                     <MaxY>623000</MaxY>
>                   </Bounds></Image>
> </Band>
> </Feature>
> </Location>
> </RasterDefinition>
> </complexType>
> </SchemaMapping>
> </fdo:DataStore>
> Thanks, everyone.
> Jason Birch wrote:
>> ECW and MrSID are not supported by default in MGOS, primarily due to
>> licensing restrictions.  We could probably bundle the MrSID DLLs from my
>> reading of the license, but there is a certain degree of risk that would
>> be
>> involved and we'd probably want to get a legal opinion first.
>> I documented some steps to add ECW and MrSID support to MapGuide, but
>> people
>> have been having mixed luck with this:
>> http://n2.nabble.com/ECWs-and-MG-2-1-tp2978248p2978703.html
>> Jason
>> 2009/11/9 Dejan Gregor <dejan.gregor at gmail.com>
>>> Dear Kenneth and HABC,
>>> is MrSID really supported my MGOS 2.1 out of the box by the GDAL provider
>>> that comes with the installation? Personally, I was not able to run it.
>>> HABC, which provider do you use for MrSID? How did you implementi it to
>>> MGOS 2.1?
>>> Dejan
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Problem-with-MrSid-in-Maestro-1-1-Mapguide-2-1-tp3964578p3983792.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
