SV: [mapguide-users] Need help with IF-statment in Tool Tip
Kratz
fredrik.kratz at helsingborg.se
Wed Nov 11 08:40:40 EST 2009
Here is the error message:
The expression is invalid
Error: Argument types for function 'If' are mismatched. Click here to move the cursor to the error (1)#1
Error: Result types are mismatched: the validation operation expected 'Text' but the expression returned 'Unknown'
It's the same whether I use If ( LENGTH(BYGGINV_2) > 0, BYGGINV_2 , 0) or If ( LENGTH(BYGGINV_2) > 0, BYGGINV_2 , ' ' )
I get the feeling that the problem is LENGTH(BYGGINV_2) > 0 but I cant understand how ?
Från: JamesDudden [via OSGeo.org] [mailto:ml-node+3986117-1900696720 at n2.nabble.com]
Skickat: den 11 november 2009 13:31
Till: Kratz Fredrik - SBF
Ämne: Re: [mapguide-users] Need help with IF-statment in Tool Tip
What does the error say? It normally points to which bit is wrong.
Is it the empty string?
Try putting a 0 instead like this:
Kratz wrote:
Hi!
I need help writing a correct string with an if-statement.
Trying to determine whether an attribute contains any value(string) or not.
Why doesn't this string work?
Default:
If ( [condition], [trueValue], [falseValue] )
Software Matters <http://www.software-matters.co.uk> - Bespoke Database <http://www.software-matters.co.uk/bespoke-database-design.html> and Software Solutions
View message @ http://n2.nabble.com/Need-help-with-IF-statment-in-Tool-Tip-tp3985605p3986117.html
To unsubscribe from Need help with IF-statment in Tool Tip, click here < (link removed) > .
View this message in context: http://n2.nabble.com/Need-help-with-IF-statment-in-Tool-Tip-tp3985605p3986496.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091111/345be11b/attachment.html
