[mapguide-users] how to check off layer in legend panel
automatically
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Nov 12 02:55:49 EST 2009
There is nothing in MapGuide that supports that right away.
You can try to look at the legend.js file and see if there is a place
where you can hook
into the legend UI and capture the check events.
Regards, Kenneth Skovhede, GEOGRAF A/S
NISHA P skrev:
> As you have said, i grouped the layers..But i did not get what i
> want..i will explain my question..
> I have 3 layers that are invisible at startup...when i click top layer
> in the legend, that layer is display in the map..
> after that when i click 2nd layer in the legend, that layer is
> displayed but can't see the layer (1st layer is on top of 2nd layer)
> How to check off 1st layer automatically when i click 2nd layer in the
> legend panel??
> Thanks and regards
> Nisha
> On Wed, Nov 11, 2009 at 6:03 PM, JamesDudden
> <jamesdudden at blueyonder.co.uk <mailto:jamesdudden at blueyonder.co.uk>>
> wrote:
> You need to group the layers that you want to control together in
> the map
> layer control.
> http://www.software-matters.co.uk Software Matters -
> http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
> Database and Software Solutions
> http://n2.nabble.com/how-to-check-off-layer-in-legend-panel-automatically-tp3984754p3986130.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> Nisha
> nisha at iiitmk.ac.in <mailto:nisha at iiitmk.ac.in>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091112/f0592ccf/attachment.html
