[mapguide-users] Label Expressions - replaceall
Zac Spitzer
zac.spitzer at gmail.com
Thu Nov 12 19:06:00 EST 2009
i did the actual string manipulation outside FDO and then
saved it again, rather than as an expression which gets
run every time.
if that didn't work, maybe try double quotes?
z
On Fri, Nov 13, 2009 at 2:34 AM, GordonL
<gordon.luckett at arrowgeomatics.com> wrote:
> Hi Zac,
> where you replaced the linefeeds, did you do something like this?
> Translate(MYFIELD, chr(12), '\n')
> Do you know how to pass ASCII in the Expression for the tool tip?
> thanks
> gordon
> zspitzer wrote:
>> that's really terribly explained, when I first saw "from-characterset"
>> with translate, I thought it was
>> something to do with code pages!
>> Translate( <text property >, <from-characterset >, <to-characterset >)
>> Would make more sense to humans as
>> Translate( <text property >, <from-string>, <to-string>)
>> I would like to see a fourth parameter, <repeat> 1 being the default,
>> 0 all or x number of times
>> z
>> On Thu, Jul 31, 2008 at 10:22 PM, Zac Spitzer <zac.spitzer at gmail.com>
>> wrote:
>>> ah, yep, strange name, that's why I missed it...
>>> turns out there's a bit more logic required to split a name nicely
>>> z
>>> On Thu, Jul 31, 2008 at 9:30 PM, Jackie C. Ng <jumpinjackie at gmail.com>
>>> wrote:
>>>> FDO has the expression function Translate( <text property >,
>>>> <from-characterset >, <to-characterset > )
>>>> Is this available in mapguide?
>>>> - Jackie
>>>> zspitzer wrote:
>>>>> Is there an expression with mapguide which can be used to do a replace
>>>>> all?
>>>>> I want to replace all newlines in a label with '\n' to split the words
>>>>> over multiple lines
>>>>> I couldn't see anything in studio
>>>>> z
>>>>> Zac Spitzer -
>>>>> http://zacster.blogspot.com (My Blog)
>>>>> +61 405 847 168
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> http://themapguyde.blogspot.com
>>>> http://www.linkedin.com/in/jackieng
>>>> View this message in context:
>>>> http://www.nabble.com/Label-Expressions---replaceall-tp18748700p18752597.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> Zac Spitzer -
>>> +61 405 847 168
>> Zac Spitzer -
>> +61 405 847 168
> View this message in context: http://n2.nabble.com/Label-Expressions-replaceall-tp1817399p3993541.html
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
+61 405 847 168
