[mapguide-users] connection with oracle
manav dayal manav_dayal85 at yahoo.co.in
Fri Nov 13 02:00:35 EST 2009
Error is still persisting. Is there any alternative way.
Do we need to include any value in the King FDO class text box.
-- - On Fri, 13/11/09, Zac Spitzer <zac.spitzer at gmail.com> wrote:
Subject: Re: [mapguide-users] connection with oracle
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Date: Friday, 13 November, 2009, 9:46 AM
try using the oracle easy connect syntax
//BIGSERVER/DEV01
which in your case will be
//servername/orcl
z
On Fri, Nov 13, 2009 at 3:06 PM, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
> When i opt for new dataconnection using oracle provider in maestro, a new source window opens. On this window I opt for specified credentials and pass the username and password.
> when i use sql prompt, it works fine with username/password at orcl.
> I need to know what should be written inside the text boxes for service,
> schema and king FDO class or do i need to make any other connection settings.
> --- On Thu, 12/11/09, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Date: Thursday, 12 November, 2009, 6:04 PM
> it is purely a error with the service name
> ORA-12154: TNS:could not resolve the connect identifier specified
> is a native error code from oracle
> what are your connection settings?
> z
> On Thu, Nov 12, 2009 at 11:01 PM, Dejan Gregor <dejan.gregor at gmail.com> wrote:
> > Do you have an Oracle client installed from where you are connecting?
> > Dejan
> > On Thu, Nov 12, 2009 at 12:58, manav dayal <manav_dayal85 at yahoo.co.in> wrote:
> >> I am using maestro1.0  and trying to  connect to the remote database server.
> >> When I choose to make a  new data connection with OSGeo.KingOracle.3.3 as the
> >> provider for oracle.
> >> Following error is being thrown when I try to test the connection.
> >> The remote server returned an error: (559) MgFdoException.:
> >> An exception occurred in FDO component.
> >> Exception occurred in method MgFdoConnectionManager.Open at line 858 in file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> >> kindly help asap.
> >> Regards.
> >> ________________________________
> >> The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
      The INTERNET now has a personality. YOURS! See your Yahoo! Homepage. http://in.yahoo.com/
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091113/ca1490b0/attachment.html
