[mapguide-users] FDO Toolbox - MapView
Nimrod Cnaan nimcnaan at hotmail.com
Mon Nov 16 04:09:33 EST 2009
unable to get mapview version 0.9.0.1033
> Date: Sun, 14 Jun 2009 16:55:03 -0700
> From: jumpinjackie at gmail.com
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] FDO Toolbox - MapView
> 1. Was your SDF produced by AutoCAD Map 2010? Map 2010 makes SDFs containing
> 3-dimensional geometries, that the map preview can't handle.
> 2. There should be an "Add" button below the computed properties. This will
> bring up the expression editor where you can enter the required expression.
> - Jackie
> Nimrod Cnaan wrote:
> > Hi Jackie
> > Grate tool, we are using it on a daily basis.
> > I have couple of problems:
> > 1. can't see sdf preview in the "Map View" tab
> > 2. how do I add a new functionality to the computed properties tab -
> > String function Expression to create a reverse string column
> >> Date: Fri, 17 Apr 2009 10:33:11 -0700
> >> Subject: Re: [mapguide-users] FDO toolbox help
> >> I've made a new release of FDO Toolbox that not only fixes the Generic
> >> control for RDBMS providers, but also provides an express SQL Server 2008
> >> spatial connection option.
> >> Cheers,
> >> - Jackie
> >> This is a defect with the Generic control that makes it unusable with
> >> RDBMS-based providers or any providers that have connection properties
> >> which are only available when connected.
> >> This will be fixed for the next release. The workaround in the meantime,
> >> would be to use the express connection method for [your RDBMS].
> >> Unfortunately, SQL Server 2008 does not have an express connection
> >> method. It will for the next release.
> >> - Jackie
> >> Hi Jackie, I am trying to use this tool in order to convert shp to
> >> sql2008.
> >> I wanted to connect to sql2008 database but with no success.
> >> I have attached a screenshot with the error that I got it.
> >> I am using the 0.7.1.2118 version.
> >> could you help me with it?
> >> thanks in advance,
> >> View this message in context:
> >> http://n2.nabble.com/FDO-toolbox-help-tp2572209p2651987.html
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > _________________________________________________________________
> > Show them the way! Add maps and directions to your party invites.
> > http://www.microsoft.com/windows/windowslive/products/events.aspx
> View this message in context: http://n2.nabble.com/FDO-toolbox-help-tp2572209p3077622.html
Windows Live Hotmail: Your friends can get your Facebook updates, right from Hotmail®.
http://www.microsoft.com/middleeast/windows/windowslive/see-it-in-action/social-network-basics.aspx?ocid=PID23461::T:WLMTAGL:ON:WL:en-xm:SI_SB_4:092009
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091116/245af254/attachment.html
