[mapguide-users] Map Inconsistencies. Is it a Network\Server
Issue??
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Nov 17 03:03:42 EST 2009
I was thinking of the FDO connection pool,
but I cannot determine anything by looking at the serverconfig values.
Regards, Kenneth Skovhede, GEOGRAF A/S
durrrr skrev:
> Hi,
> Thanks for your reply.
> I have added some details from my server setup. Do these numbers look ok?
> General Properties
> TCP/IP maximum transmission unit: 1460
> Connection timeout (seconds): 120
> Connection timer interval (seconds): 60
> Client Connection Properties
> Maximum connections: 100
> Maximum queued operations: 40
> Maximum threads in pool: 20
> Site Connection Properties
> Maximum connections: 20
> Maximum queued operations: 20
> Maximum threads in pool: 10
> Thanks
> Durrrr
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> It sounds as if you are exhausting some resource.
>> One guess is that you are maxing out your connectionpool, so the FDO
>> provider locks up.
>> Another possibility is that your provider is using too many filehandles,
>> and then stops working.
>> For both the possibilities, try limiting the number of connection pool
>> entries in the serverconfig.ini,
>> and see if the problem gets better or worse (raising the limit is likely
>> a bad solution).
>> durrrr skrev:
>>> Hi,
>>> We are having a great deal of difficulties with the consistency of
>>> layers,
>>> points and searches on our map.
>>> It seems works perfectly 10 times but then suddenly things stop working
>>> such
>>> as search's or suddenly the map wont display at all.
>>> Because these issues are intermittent i can think of no other explanation
>>> other than slow network\Server.
>>> Currently we have a map with 55 layers (os, raster, point, line) it is
>>> running on a Windows server using Apache, we have a seperate server for
>>> our
>>> maps and it is being viewed over the internet.
>>> If anyone can help or suggest anything i would appreciate it!
>>> (I am relativly new to the whole mapping development role so simplified
>>> questions are appreciated!)
>>> Thanks in advance
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091117/396332d8/attachment.html
