[mapguide-users] Launch Sample Application error
badgerseatfrogs
peterdonaldmackenzie at gmail.com
Tue Nov 17 23:29:27 EST 2009
I am having the same 404 Error described below, I have a mapviewerphp folder
in my www folder
Any progress on what to do...? Is there other APACHE stuff you need to
install.
Barker, Andrew (Melbourne) wrote:
> I don't know whether I am running apache or not. All I have done is
> download the files and follow the steps set out in
> http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/GettingStarted.pdf
> Nothing more, no other installs. The problem is just that the last step
> doesn't launch the map viewer, well, it tries but says it can't find it.
> I tried altering the address as you suggested but still no dice.
> Any more clues?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
> Sent: Saturday, 18 July 2009 12:48 AM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] RE: Launch Sample Application error
> You suggested Apache when you included a link that has the 8008 port. If
> you aren't using apache remove the 8008 port from your URL. That may be
> your only issue ;)
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Barker,
> Andrew (Melbourne)
> Sent: Thursday, July 16, 2009 10:33 PM
> Thanks for the reply Dave.
> I checked the location you specified and there is a folder in there named
> mapviewerphp, so I guess that answers the first part of the question, I
> have the php version installed.
> Does that bring me closer to getting step 5 from the instructions to work
> and the viewer and map to display?
> PS. Where did I say anything about apache?
> Sent: Friday, 17 July 2009 1:51 AM
> Check your www folder in your Web Extensions install. the mapviewerXXX
> will tell you which API you installed. I'm guessing if you are running
> apache you probably installed PHP. If you didn't things probably won't
> work.
> Dav0065
> Andrew (Melbourne)
> Sent: Thursday, July 16, 2009 1:37 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Launch Sample Application error
> Hi guys, long time listener, first time caller.
> I'm new to mapguide and I've followed the steps laid out in
> Everything seems to go swimmingly, I realised the .mgp was being renamed
> to .zip and I rename that. I proceed to step 4 and load the package
> successfully, great, then when I go to step 5 (go to the link:
> http://localhost:8008/mapguide/phpviewersample/ajaxtiledviewersample.php)
> I get a 404 error.
> To try and investigate what I'm doing wrong I browse to Web Studio. In
> there I can see the various layers of Sheboygan, they all seem to have
> loaded correctly. It just seems as though the viewer isn't working
> correctly. What might I be missing for this final step not to work but
> everything else apparently loading correctly?
> Also, I can't remember whether I installed php or asp, where do I look to
> check? Secondly, lots of people talk about logging out of the admin agent
> and restarting the server/service. How do I go about this?
> I'm running XP 64 with IE 7, MapGuide open source 2.0.2 and I am just
> trying to test this locally.
> Any clues or suggestions of silly things I've missed would be greatly
> appreciated. No one else on the forum seems to have quite the same
> problem I have, with the final step failing.
> Regards,
> Andrew Barker
> *** WORLEYPARSONS GROUP NOTICE ***
> "This email is confidential. If you are not the intended recipient, you
> must not disclose or use the information contained in it.
> If you have received this email in error, please notify us immediately by
> return email and delete the email and any attachments.
> Any personal views or opinions expressed by the writer may not
> necessarily reflect the views or opinions of any company in the
> WorleyParsons Group of Companies."
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Launch-Sample-Application-error-tp3270646p4023347.html
