[mapguide-users] mapguide server crashs even for 5 users
sathishpsk9 sathishpsk9 at gmail.com
Wed Nov 18 04:36:45 EST 2009
hi all
i am using
mapguide server     2.0(mgos)
maestro                1.0.9
.NET framework      2.0
IIS                       5.0
windows xp professional (sp3)
king oracle fdo (3.3)
oracle 10g spatial
p IV (3.2GHz),512mb ram.
when i run the application with 5 users ,after 6 th user mapguide server
crashs.so i tested the application in load runner 9.01 it gave the result as
follows:
Analysis Summary	Period: 10/11/2009 13:03:03 - 10/11/2009 13:08:54
Scenario Name:	D:\HP\LoadRunner\scenario\Ghazia_10.lrs
Results in Session:	C:\Documents and Settings\srw\Local
Settings\Temp\res\res.lrr
Duration:	5 minutes and 51 seconds.
Statistics Summary
Maximum Running Vusers:
	5
Total Throughput (bytes):
28,291,753
Average Throughput (bytes/second):
80,374
Total Hits:
3,729
Average Hits per Second:
10.594	  View HTTP Responses Summary
Total Errors:
24
You can define SLA data using the SLA configuration wizard
You can analyze transaction behavior using the Analyze Transaction mechanism
 Scenario Behavior Over Time
The SLA status of the following measurements displayed over time. You can
select a specific time range for each transaction in order to analyze the
time range.
Measurement Name	Time Ranges
Application Under Test Errors	0
 	0
 	0.6
 	0.3
 	0
 	0.2
 	0
 	0
 	0
 	0
 	0
 	0
 	0
 	0
 	0
 	0
 	0
 	0
	00:00:00	00:00:15	00:00:35	00:00:55	00:01:15	00:01:35	00:01:55	00:02:15
00:02:35	00:02:55	00:03:15	00:03:35	00:03:55	00:04:15	00:04:35	00:04:55
00:05:15	00:05:35
 Transaction Summary
Transactions:
Total Passed: 208	Total Failed: 38	Total Stopped: 0	         Average
Response Time
Transaction Name	SLA Status	Minimum	Average	Maximum	Std. Deviation	90
Percent	Pass	Fail	Stop
Action_Transaction
51.214	60.956	103.222	14.872	95.925	25	19	0
Home
4.077	4.176	4.324	0.083	4.276	27	0	0
Login
12.321	21.342	48.682	10.433	41.326	27	17	0
maoInfi
1.929	2.278	2.818	0.201	2.46	25	2	0
Map
0.028	0.041	0.161	0.026	0.047	25	0	0
Map1
0.007	0.012	0.07	0.013	0.012	25	0	0
URL
0.075	1.936	16.405	5.007	15.645	44	0	0
vuser_end_Transaction
0	0	0	0	0	5	0	0
vuser_init_Transaction
0	0	0	0	0	5	0	0
Service Level Agreement Legend:
Pass
Fail
No Data
HTTP Responses	Total	Per second
HTTP_200
3,260	9.261
HTTP_302
44	0.125
HTTP_401
1	0.003
HTTP_403
309	0.878
HTTP_404
115	0.327
plz help me...
sathish
View this message in context: http://n2.nabble.com/mapguide-server-crashs-even-for-5-users-tp4024330p4024330.html
