[mapguide-users] mapguide server crashs even for 5 users
sathishpsk9 sathishpsk9 at gmail.com
Wed Nov 18 05:39:30 EST 2009
hi
thanks for reply.
and the error log is :
# Log Type: Error Log
# Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
<2009-08-05T12:32:54> 			Administrator
 Error: Resource was not found: Library://proptax/layout.WebLayout
 StackTrace:
  - MgResourceServiceHandler.ProcessOperation line 80 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
  - MgOpGetResourceContent.Execute line 120 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpGetResourceContent.cpp
  - MgServerResourceService.GetResourceContent line 863 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ServerResourceService.cpp
  - MgApplicationRepositoryManager.GetResourceContent line 378 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
  - MgResourceDefinitionManager.GetResource line 320 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
  - MgResourceContentManager.GetDocument line 590 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceContentManager.cpp
  - MgResourceDefinitionManager.GetDocument line 476 file
<2009-08-05T13:33:30>
 Error: Session has expired or is invalid. Please log in again.
 StackTrace:
  - MgSiteServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\site\SiteServiceHandler.cpp
  - MgOpAuthenticate.Execute line 107 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\site\OpAuthenticate.cpp
  - MgSecurityManager.Authenticate line 224 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\SecurityManager.cpp
  - MgSessionCache.GetSessionInfo line 175 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\SessionCache.cpp
<2009-08-11T17:10:50> 			Administrator
Library://SonshpProp/imcshpproplayout.WebLayout
 StackTrace:
Resource was not found: Library://SonshpProp/imcshpproplayout.WebLayout
<2009-08-11T18:00:28> 			Administrator
 Error: Resource was not found: Library://thematic/layout.WebLayout
 StackTrace:
<2009-08-11T18:00:57> 			Administrator
 StackTrace:
<2009-08-11T18:01:12> 			Administrator
 StackTrace:
<2009-08-11T18:01:14> 			Administrator
 StackTrace:
<2009-08-11T18:01:19> 			Administrator
 StackTrace:
<2009-08-11T18:01:28> 			Administrator
 StackTrace:
<2009-08-11T18:01:58> 			Administrator
 StackTrace:
<2009-08-11T18:02:49> 			Administrator
 StackTrace:
<2009-08-11T18:03:30> 			Administrator
 StackTrace:
<2009-08-11T18:05:48> 			Administrator
 StackTrace:
<2009-08-11T18:05:59> 			Administrator
 StackTrace:
<2009-08-11T18:06:59> 			Administrator
 StackTrace:
<2009-08-11T18:23:09> 			Administrator
 StackTrace:
<2009-08-11T18:26:30> 			Administrator
 StackTrace:
<2009-08-11T18:31:57> 			Administrator
 StackTrace:
<2009-08-11T18:32:06>
 Error: Authentication failed.  Please enter a valid username and password.
 StackTrace:
  - MgSecurityManager.Authenticate line 190 file
<2009-08-11T18:38:17> 			Administrator
 StackTrace:
 StackTrace:
<2009-08-11T18:39:36> 			Administrator
 StackTrace:
<2009-08-11T18:39:37>
 StackTrace:
<2009-08-11T18:41:36> 			Administrator
 StackTrace:
<2009-08-11T18:42:12> 			Administrator
 StackTrace:
<2009-08-11T18:42:44> 			Administrator
 StackTrace:
<2009-08-11T18:44:40> 			Administrator
 StackTrace:
<2009-08-11T19:13:55> 			Administrator
 StackTrace:
<2009-08-11T20:29:50> 			Administrator
 Error: Invalid argument(s):
        The value cannot be less than or equal to zero.
 StackTrace:
  - MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
  - MgOpQueryFeatures.Execute line 125 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
  - MgServerRenderingService.QueryFeatures line 652 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\ServerRenderingService.cpp
  - MgServerRenderingService.RenderForSelection line 1041 file
<2009-08-11T20:29:51> 			Administrator
 StackTrace:
<2009-08-11T20:29:59> 			Administrator
 StackTrace:
<2009-08-11T20:47:09> 			Administrator
 StackTrace:
<2009-08-11T21:04:21> 			Administrator
 StackTrace:
<2009-08-11T21:07:48> 			Administrator
 StackTrace:
<2009-08-11T21:07:52> 			Administrator
 StackTrace:
<2009-08-11T21:07:56> 			Administrator
 StackTrace:
<2009-08-11T21:08:18> 			Administrator
 StackTrace:
<2009-08-11T21:08:27> 			Administrator
 StackTrace:
<2009-08-11T21:08:34> 			Administrator
 StackTrace:
<2009-08-11T21:08:37> 			Administrator
 StackTrace:
<2009-08-12T20:20:16> 			Administrator
Session:59351c7e-0000-1000-8000-000b6a90df2a_en_7F0000010AFC0AFB0AFA//map.Map
 StackTrace:
  - MgOpGetResourceData.Execute line 124 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpGetResourceData.cpp
  - MgServerResourceService.GetResourceData line 1401 file
  - MgApplicationRepositoryManager.GetResourceData line 1201 file
<2009-08-21T13:01:02> 			Administrator
 StackTrace:
<2009-08-21T13:01:17> 			Administrator
 StackTrace:
 StackTrace:
<2009-08-21T13:28:12> 			Administrator
 Error: An exception occurred in DB XML component.
        Error: XML Indexer:  Parse error in document at line, 1, char 1833.
Parser message: Empty content not valid for content model:
'(AreaRule,ExtendedData1)'
 StackTrace:
  - MgOpSetResource.Execute line 103 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpSetResource.cpp
  - MgServerResourceService.SetResource line 713 file
  - MgRepositoryManager.SetResource line 867 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\RepositoryManager.cpp
  - MgRepositoryManager.AddResource line 840 file
  - MgResourceContentManager.AddResource line 183 file
  - MgResourceContentManager.PutDocument line 624 file
  - MgResourceDefinitionManager.PutDocument line 554 file
Error: XML Indexer:  Parse error in document at line, 1, char 1833. Parser
<2009-08-21T13:28:13> 			Administrator
 StackTrace:
<2009-09-03T11:25:29>
 StackTrace:
<2009-09-07T16:14:43>
 StackTrace:
<2009-09-07T16:14:58>
 StackTrace:
<2009-09-07T16:15:00>
 StackTrace:
<2009-09-07T16:15:09>
 StackTrace:
<2009-09-07T16:15:13>
 StackTrace:
<2009-09-07T16:15:14>
 StackTrace:
<2009-09-07T16:15:22>
 StackTrace:
<2009-09-07T16:15:24>
 StackTrace:
 StackTrace:
<2009-09-07T16:16:24>
 StackTrace:
<2009-09-07T16:16:35>
 StackTrace:
<2009-09-07T16:16:38>
 StackTrace:
<2009-09-07T16:16:42>
 StackTrace:
<2009-09-07T16:16:49>
 StackTrace:
please help me
thanks
sathish
zspitzer wrote:
> what does the mapguide error log say?
> On Wed, Nov 18, 2009 at 8:36 PM, sathishpsk9 <sathishpsk9 at gmail.com>
> wrote:
>> hi all
>> i am using
>> mapguide server     2.0(mgos)
>> maestro                1.0.9
>> .NET framework      2.0
>> IIS                       5.0
>> windows xp professional (sp3)
>> king oracle fdo (3.3)
>> oracle 10g spatial
>> p IV (3.2GHz),512mb ram.
>> when i run the application with 5 users ,after 6 th user mapguide server
>> crashs.so i tested the application in load runner 9.01 it gave the result
>> as
>> follows:
>> Analysis Summary        Period: 10/11/2009 13:03:03 - 10/11/2009 13:08:54
>> Scenario Name:  D:\HP\LoadRunner\scenario\Ghazia_10.lrs
>> Results in Session:     C:\Documents and Settings\srw\Local
>> Settings\Temp\res\res.lrr
>> Duration:       5 minutes and 51 seconds.
>> Statistics Summary
>> Maximum Running Vusers:
>>        5
>> Total Throughput (bytes):
>> 28,291,753
>> Average Throughput (bytes/second):
>> 80,374
>> Total Hits:
>> 3,729
>> Average Hits per Second:
>> 10.594    View HTTP Responses Summary
>> Total Errors:
>> 24
>> You can define SLA data using the SLA configuration wizard
>> You can analyze transaction behavior using the Analyze Transaction
>> mechanism
>>  Scenario Behavior Over Time
>> The SLA status of the following measurements displayed over time. You can
>> select a specific time range for each transaction in order to analyze the
>> time range.
>> Measurement Name        Time Ranges
>> Application Under Test Errors   0
>>        0
>>        0.6
>>        0.3
>>        0
>>        0.2
>>        0
>>        0
>>        0
>>        0
>>        0
>>        0
>>        0
>>        0
>>        0
>>        0
>>        0
>>        0
>>        00:00:00        00:00:15        00:00:35        00:00:55
>>  00:01:15        00:01:35        00:01:55        00:02:15
>> 00:02:35        00:02:55        00:03:15        00:03:35        00:03:55
>>      00:04:15        00:04:35        00:04:55
>> 00:05:15        00:05:35
>>  Transaction Summary
>> Transactions:
>> Total Passed: 208       Total Failed: 38        Total Stopped: 0
>>       Average
>> Response Time
>> Transaction Name        SLA Status      Minimum Average Maximum Std.
>> Deviation  90
>> Percent Pass    Fail    Stop
>> Action_Transaction
>> 51.214  60.956  103.222 14.872  95.925  25      19      0
>> Home
>> 4.077   4.176   4.324   0.083   4.276   27      0       0
>> Login
>> 12.321  21.342  48.682  10.433  41.326  27      17      0
>> maoInfi
>> 1.929   2.278   2.818   0.201   2.46    25      2       0
>> Map
>> 0.028   0.041   0.161   0.026   0.047   25      0       0
>> Map1
>> 0.007   0.012   0.07    0.013   0.012   25      0       0
>> URL
>> 0.075   1.936   16.405  5.007   15.645  44      0       0
>> vuser_end_Transaction
>> 0       0       0       0       0       5       0       0
>> vuser_init_Transaction
>> 0       0       0       0       0       5       0       0
>> Service Level Agreement Legend:
>> Pass
>> Fail
>> No Data
>> HTTP Responses  Total   Per second
>> HTTP_200
>> 3,260   9.261
>> HTTP_302
>> 44      0.125
>> HTTP_401
>> 1       0.003
>> HTTP_403
>> 309     0.878
>> HTTP_404
>> 115     0.327
>> plz help me...
>> sathish
>> View this message in context:
>> http://n2.nabble.com/mapguide-server-crashs-even-for-5-users-tp4024330p4024330.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/mapguide-server-crashs-even-for-5-users-tp4024330p4024594.html
