[mapguide-users] FeatureService.UpdateFeatures insert feature
correctly into the Oracle but not return MgFeatureProperty
mighty_duck
msiljegovic at gmail.com
Wed Nov 18 08:08:34 EST 2009
Hello,
I want to insert data into the oracle table using
FeatureService.UpdateFeatures and everything works fine, new feature is
inserted into the database, but if I want to see ID(autogenerated in
database) of data that I inserted(should return MgFeatureProperty for Insert
command) I got an MgStringProperty with exception text. This is the case
when Im using Autodesk Oracle provider.
When Im using, for same code, FDOKing provider FeatureService.UpdateFeatures
returns MgFeatureProperty but then when I want to read data from
FeatureReader(ReadNext gives me true) I get null reference exception(Does it
mean that reader is empty?).
Does anyone know what is the problem and does this mean that if I want to
find out ID for inserted feature in database, I want be able to do that via
FeatureService?
anyinformation will be very helpful,
thanks
View this message in context: http://n2.nabble.com/FeatureService-UpdateFeatures-insert-feature-correctly-into-the-Oracle-but-not-return-MgFeaturePropey-tp4025280p4025280.html
