[mapguide-users] How to add layer to the map on the fly???
MichaelGl
michael_gl at stav-gis.com
Thu Nov 19 06:43:54 EST 2009
I'm trying to add temporary layer to the map and I'm fail. Please help...
I have a button :
<input type="button" value="Start" onclick="DigitizePolygon();">
This is the client side code :
<script type="text/javascript">
function submitRequest()
var pageUrl =
document.getElementById("hfTargetURL").getAttribute("value");
var pointsStr =
document.getElementById("hfPoints").getAttribute("value");
params = new Array(
"SESSION", parent.parent.mapFrame.GetSessionId(),
"MAPNAME", parent.parent.mapFrame.GetMapName(),
"POINTS", pointsStr
parent.parent.formFrame.Submit(pageUrl, params, "scriptFrame");
function DigitizePolygon()
var lblBox = document.getElementsByName("lblArea");
lblBox[0].innerText = "";
parent.parent.mapFrame.DigitizePolygon(OnPolygonDigitized);
function OnPolygonDigitized(poly)
ShowResults(CalculatePolygonArea(poly));
function CalculatePolygonArea(line)
var str = "";
var res = 0;
var tmpInt = 0;
var pointsStr = line.Count.toString() + ",";
for (var i = (line.Count - 1); i > 0; i--)
var currP = line.Point(i);
var nextP = line.Point(i - 1);
res += ((currP.X * nextP.Y) - (nextP.X * currP.Y));
pointsStr += currP.X.toString() + "," + currP.Y.toString() +
if (i == 1)
pointsStr += nextP.X.toString() + "," + nextP.Y.toString();
res /= 2;
tmpInt = parseInt(res * 100);
res = tmpInt / 100;
res = (res < 0) ? (res * -1) : res;
str = res.toString();
document.getElementById("hfPoints").setAttribute("value",
pointsStr);
return str;
function ShowResults(res)
lblBox[0].innerText = res ;
submitRequest();
</script>
I'm passing all the points of the digitized polygon to the server side,and
this is the code of the server side
C# :
<script runat="server">
ArrayList xpts = new ArrayList();
ArrayList ypts = new ArrayList();
const string templPath = "c:\\Program
Files\\MapGuideOpenSource2.0\\WebServerExtensions\\www\\viewerfiles\\";
protected void Page_Load(object sender, EventArgs e)
double centerX, centerY;
NameValueCollection requestParams;
try
// Initialize and get request parameters
InitializeWebTier();
requestParams = GetRequestParameters();
String mgSessionId = requestParams["SESSION"];
String mgLocale = requestParams["LOCALE"];
String mgMapName = requestParams["MAPNAME"];
string pointsStr = requestParams["POINTS"];
string layerName = "Lines";
string layerLegendLabel = "New Lines";
string groupName = "Analysis";
string groupLegendLabel = "Analysis";
string featureSourceName = "Session:" + mgSessionId +
"//TemporaryLines.FeatureSource";
BuildPointsLists(pointsStr);
// Connect to the site and create a session
MgUserInformation userInfo = new MgUserInformation(mgSessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
// Get an instance of the required service.
MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
MgFeatureService featureService =
siteConnection.CreateService(MgServiceType.FeatureService) as
MgFeatureService;
// Initiate the map
MgMap map = new MgMap(siteConnection);
map.Open(mgMapName);
MgResourceIdentifier resId = new
MgResourceIdentifier(featureSourceName);
bool featureSourceExists = DoesResourceExist(resId,
resourceService);
if (featureSourceExists == false)
// Create a temporary feature source to draw the lines on
// Create a feature class definition for the new feature
source
MgClassDefinition classDefinition = new MgClassDefinition();
classDefinition.SetName("Lines");
classDefinition.SetDescription("Lines to display.");
string geometryPropertyName = "SHPGEOM";
classDefinition.SetDefaultGeometryPropertyName(geometryPropertyName);
// Create an identify property
MgDataPropertyDefinition identityProperty = new
MgDataPropertyDefinition("KEY");
identityProperty.SetDataType(MgPropertyType.Int32);
identityProperty.SetAutoGeneration(true);
identityProperty.SetReadOnly(true);
// Add the identity property to the class definition
classDefinition.GetIdentityProperties().Add(identityProperty);
classDefinition.GetProperties().Add(identityProperty);
// Create a name property
MgDataPropertyDefinition nameProperty = new
MgDataPropertyDefinition("NAME");
nameProperty.SetDataType(MgPropertyType.String);
// Add the name property to the class definition
classDefinition.GetProperties().Add(nameProperty);
// Create a geometry property
MgGeometricPropertyDefinition geometryProperty = new
MgGeometricPropertyDefinition(geometryPropertyName);
geometryProperty.SetGeometryTypes(MgFeatureGeometricType.Surface);
// Add the geometry property to the class definition
classDefinition.GetProperties().Add(geometryProperty);
// Create a feature schema
MgFeatureSchema featureSchema = new
MgFeatureSchema("SHP_Schema", "Line schema");
// Add the feature schema to the class definition
featureSchema.GetClasses().Add(classDefinition);
// Create the feature source
string wkt = map.GetMapSRS();
MgCreateSdfParams sdfParams = new MgCreateSdfParams("spatial
context", wkt, featureSchema);
featureService.CreateFeatureSource(resId, sdfParams);
// Add the line to the feature source
MgBatchPropertyCollection batchPropertyCollection = new
MgBatchPropertyCollection();
for (int idx = 0; idx < xpts.Count - 1; idx++)
string lineName = "Line " + (idx + 1).ToString();
MgPropertyCollection propertyCollection = MakeLine(lineName,
Convert.ToDouble(xpts[idx]),
Convert.ToDouble(ypts[idx]),
Convert.ToDouble(xpts[idx + 1]),
Convert.ToDouble(ypts[idx + 1]));
batchPropertyCollection.Add(propertyCollection);
// Add the batch property collection to the feature source
MgInsertFeatures cmd = new MgInsertFeatures(layerName,
batchPropertyCollection);
MgFeatureCommandCollection featureCommandCollection = new
MgFeatureCommandCollection();
featureCommandCollection.Add(cmd);
// Execute the "add" commands
featureService.UpdateFeatures(resId, featureCommandCollection,
false);
bool layerExists = DoesLayerExist(layerName, map);
if (layerExists == false)
// Create a new layer which uses that feature source
// Create a line rule to stylize the lines
string ruleLegendLabel = "Lines Rule";
string filter = "";
string color = "FF0000FF";
string lineRule = ReadFileAsString(templPath +
"linerule.templ");
String[] vals = { ruleLegendLabel, filter, color };
lineRule = Substitute(lineRule, vals);
// Create a line type style
string lineTypeStyle = ReadFileAsString(templPath +
"linetypestyle.templ");
String[] valsStyle = { lineRule };
lineTypeStyle = Substitute(lineTypeStyle, valsStyle);
// Create a scale range
string minScale = "0";
string maxScale = "1000000000000";
string lineScaleRange = ReadFileAsString(templPath +
"scalerange.templ");
String[] valsScale = { minScale, maxScale, lineTypeStyle };
lineScaleRange = Substitute(lineScaleRange, valsScale);
// Create the layer definiton
string featureName = "SHP_Schema:Lines";
string geometry = "SHPGEOM";
string layerDefinition = ReadFileAsString(templPath +
"layerdefinition.templ");
String[] valsLayerDef = { featureSourceName, featureName,
geometry, lineScaleRange };
layerDefinition = Substitute(layerDefinition, valsLayerDef);
// Add the layer to the map
MgLayer newLayer = new MgLayer(resId, resourceService);
newLayer.SetName(layerName);
newLayer.SetLegendLabel(layerLegendLabel);
newLayer.SetLayerDefinition(resId, resourceService);
// Add the layer to a layer group
MgLayerGroup newGroup = new MgLayerGroup(groupName);
newGroup.SetLegendLabel(layerLegendLabel);
map.GetLayerGroups().Add(newGroup);
map.GetLayers().Insert(0, newLayer);
// Turn on the visibility of this layer.
// (If the layer does not already exist in the map, it will be
visible by default when it is added.
// But if the user has already run this script, he or she may
have set the layer to be invisible.)
MgLayerCollection layerCollection = map.GetLayers();
if (layerCollection.Contains(layerName))
MgLayerBase linesLayer = layerCollection.GetItem(layerName);
linesLayer.SetVisible(true);
MgLayerGroupCollection groupCollection = map.GetLayerGroups();
if (groupCollection.Contains(groupName))
MgLayerGroup analysisGroup =
groupCollection.GetItem(groupName);
analysisGroup.SetVisible(true);
// Save the map back to the session repository
string sessionIdName = "Session:" + mgSessionId + "//" +
mgMapName + ".Map";
MgResourceIdentifier sessionResourceID = new
MgResourceIdentifier(sessionIdName);
sessionResourceID.Validate();
map.Save(resourceService, sessionResourceID);
catch (Exception ex)
Response.Write(ex.Message);
void BuildPointsLists(string p_pointsStr)
string[] parameters = p_pointsStr.Split(',');
int length = Convert.ToInt32(parameters[0]);
for (int idx = 1; idx <= (length * 2); idx+=2)
xpts.Add(Convert.ToDouble(parameters[idx]));
ypts.Add(Convert.ToDouble(parameters[idx + 1]));
bool DoesResourceExist(MgResourceIdentifier p_redId, MgResourceService
p_resSrvc)
// Returns true if the resource already exists, or false otherwise
try
p_resSrvc.GetResourceContent(p_redId);
catch (MgResourceNotFoundException e)
return false;
return true;
MgPropertyCollection MakeLine(string p_name, double p_x0, double p_y0 ,
double p_x1, double p_y1)
MgPropertyCollection propertyCollection = new
MgPropertyCollection();
MgStringProperty nameProperty = new MgStringProperty("NAME",
p_name);
propertyCollection.Add(nameProperty);
MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
string linestring = "LINESTRING XY (" + p_x0.ToString() + " " +
p_y0.ToString() + ", " +
p_x1.ToString() + " " + p_y1.ToString() + ")";
MgGeometry geometry = wktReaderWriter.Read(linestring) as
MgLineString;
MgByteReader geometryByteReader = agfReaderWriter.Write(geometry);
MgGeometryProperty geometryProperty = new
MgGeometryProperty("SHPGEOM", geometryByteReader);
propertyCollection.Add(geometryProperty);
return propertyCollection;
bool DoesLayerExist(string p_layerName, MgMap p_map)
// Returns true if the layer already exists, or false otherwise
MgLayerCollection layerCollection = p_map.GetLayers();
return (layerCollection.Contains(p_layerName) ? true : false);
string ReadFileAsString(string p_fName)
string sContents = string.Empty;
System.IO.StreamReader sr = new System.IO.StreamReader(p_fName);
sContents = sr.ReadToEnd();
sr.Close();
return sContents;
String Substitute(String templ, String[] vals)
StringBuilder res = new StringBuilder();
int index = 0, val = 0;
bool found;
do
found = false;
int i = templ.IndexOf('%', index);
if (i != -1)
found = true;
res.Append(templ.Substring(index, i - index));
if (i < templ.Length - 1)
if (templ[i + 1] == '%')
res.Append('%');
else if (templ[i + 1] == 's')
res.Append(vals[val++]);
else
res.Append('@'); //add a character illegal in
jscript so we know the template was incorrect
index = i + 2;
} while (found);
res.Append(templ.Substring(index));
return res.ToString();
</script>
function OnPageLoad()
parent.mapFrame.Refresh();
</script>
The problem is that the polygon is not appear on the map. What am I
missing???
Thanks a lot.
View this message in context: http://n2.nabble.com/How-to-add-layer-to-the-map-on-the-fly-tp4031367p4031367.html
