[mapguide-users] Help with the Tooltip
Gustavo Ribeiro gustavo.dias.ribeiro at gmail.com
Tue Nov 24 08:07:39 EST 2009
Kori,
I changed the css as you said and nothing happen', the pop-up still cutting.
Seems like there isn't interaction between Maptip.css and the map. It's
dinamic.
Kori Maleski wrote:
> If you are using a Fusion Web Layout, you can make changes to the MapTip
> css
> file to control the display:
> C:\Program Files\OSGeo\MapGuide\Web\www\fusion\widgets\Maptip\Maptip.css
> And/or you may override them with your layouts own css.
> Cheers,
> Kori Maleski
> On Mon, Nov 23, 2009 at 12:28 PM, Gustavo Ribeiro <
> gustavo.dias.ribeiro at gmail.com> wrote:
>> Does anyone know how to centralize a pop-up in MapGuide? My pop-up is
>> cutting. http://centroautodesk.ctallen.com.br/tooltip2.jpg
>> I'm use the concat:
>> concat(concat('<iframe src="
>> http://www.portal.intragov.rj.gov.br/gespi_educacao/mapas/escola.aspx?escola=
>> Descricao        ), '"  frameborder="0" width="650px" height="140px"
>> "></iframe>')
>> http://n2.nabble.com/file/n4053306/tooltip2.jpg
>> View this message in context:
>> http://n2.nabble.com/Help-with-the-Tooltip-tp4053306p4053306.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Help-with-the-Tooltip-tp4053306p4057627.html
