[mapguide-users] Installation error
Jason Birch
jason at jasonbirch.com
Wed Nov 25 13:48:53 EST 2009
Copy of my answer on "Internals":
The installer requires that the default website still exists; for IIS6 this
means that both the internal ID and name are unchanged from the default.
IIS7 I think only requires that the name is available. The important
variables are SITE_ID and MG_WEBSITE:
http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Installers/MapGuide/MapGuide.wxs#L51
Which are used in:
IIS6:
http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS.wxs
IIS7:
http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS7.wxs
If you have renamed or deleted the default site, the installation will fail.
One of the wishlist items for the installer is a dropdown of websites to
choose from, but it will require some development work.
In the meantime, you can perform a manual install, and configure the IIS
integration manually. This is a bit of a pain and not well documented;
perhaps we should look at setting up some scripts that could be easily
edited and run by users for this...
If you haven't renamed / deleted the default website, we'll need you to
enable the Windows Installer log and try again, providing us with a location
to download the log from. This page shows how to enable MSI logging:
http://support.microsoft.com/kb/223300
Jason
2009/11/25 Flipper <scotth at mpowerinnovations.com>
> Sorry Windows 200 Server on this one
> Flipper wrote:
> > Let me reword that a little when i said host headears I meant subdomains
> > gis.website.com wiki.website.com etc.
> > Flipper wrote:
> >> I'm having the same problem...We are using host headers I changed the
> >> default back to All unassigned and its still Giving me the rollback
> after
> >> the Failed while
> >> processing WebVirtualDirs (-2147024894).
> >> HELP!!!!
> >> Fraser Burgess wrote:
> >>> Hi All,
> >>> I get the following error when installing MGOS2.1: Failed while
> >>> MGOS2.1 - IIS / .NET configuration
> >>> Windows Server 2003 SP2
> >>> After clicking the okay button on the error message the install rolls
> >>> back
> >>> Any ideas on how to fix?
> >>> Fraser
> >>> _______________________________________________
> >>> mapguide-users mailing list
> >>> mapguide-users at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Installation-error-tp3858392p4066230.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091125/1ec71b78/attachment.html
