[mapguide-users] Disable zoom and drag on one map, but not onother.
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Nov 27 06:35:49 EST 2009
I don't think the information about the two avalible methods are correct.
Generally, for a MapGuide call, you can either supply SESSION= or
USERNAME=&PASSWORD=
The purpose of this is authentication, and either works (I think
APPLYPACKAGE is different?).
You cannot use MAPNAME because that requires that you have pre-created a
runtime map in the
given session, and there is no HTTP interface to create or manipulate a
runtime map.
Try tagging a valid SESSION= parameter to the GETMAPIMAGE call, and it
should work well.
Alternatively try using USERNAME=Anonymous&PASSWORD=
Regards, Kenneth Skovhede, GEOGRAF A/S
Bojan Franc @ FER skrev:
> Thx for help.
> I am trying to use getMapImage now, it does exactly what I need.
> I just cant get it working with SESSION and MAP parameters.
> It says...
> Session Id and Map Name
> ... or ...
> Locale and Client Agent and Map Definition.
> It works with the second set of parameters, but requires a login each
> time I open the page.
> With Session Id and Map Name I get an error...
> MgResourceNotFoundException
> Resource was not found:
> Session:034a83a2-bd61-102c-8000-000c2993e1ac_en_7F0000010AFC0AFB0AFA//Demo.Map
> I am using the same variables for calling the WebLayout of my detailed
> map, and it works fine.
> I also tried to copy/paste session and map name into MapAgent
> interface, but get the same error.
> My variable shows me MapName "Demo", and the error says "Demo.Map". It
> added the ".Map" at the end of the string.
> Where can I read more about getMapImage and similar API functions? I
> was looking for it in MapGuide Web API Reference and MapGuide Viewer
> API Reference but was unable to find anything related.
> Regards,
>    Bojan Franc
> ----- Original Message ----- From: "Kenneth Skovhede, GEOGRAF A/S"
> <ks at geograf.dk>
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Sent: Thursday, November 19, 2009 8:56 AM
> Subject: Re: [mapguide-users] Disable zoom and drag on one map, but
> not onother.
>> For the "static" map, you could simply use the GETMAPIMAGE call,
>> and then manually control layer visibility.
>> Basically:
>> 1) On startup, create the MG session and runtime map
>> 2) Create a html page with an <img> pointing to:
>> http://servername/mapaguide/mapagent/mapagent.fcgi?OPERATION=GETMAPIMAGE&SESSION=<sessionid>&MAPNAME=<runtimemapname>&seq=<random
>> number>
>> 3) Start a javascript that reloads the <img> with a new random number
>> each 60 seconds
>> 4) Provide controls to turn on/off layers and toggle these in server
>> code
>> If you need a full viewer (eg, tile support, etc.), you can use
>> OpenLayers to display the map,
>> and disable the navigation controls. It would be a little bit
>> difficult to use a standard WebLayout and disable all
>> mouse controls.
>> *) The GETMAPIMAGE call probably requires more parameters, check the
>> test page:
>> http://localhost/mapguide/mapagent/index.html
>> BojanFranc at FER skrev:
>>> Hi,
>>> I need to make 2 maps. One windowed (small) with no ability to zoom
>>> or move.
>>> The other full screen map with all the features MapGuide has.
>>> First map should be a static map refreshing every 1 minute but users
>>> should
>>> not be able to zoom on it or move. It should be a "static" map. What
>>> the
>>> users should be able to do is to enable and disable some layers on
>>> the map,
>>> nothing more. It's like a "demo" map for unregistered users.
>>> The second map will be available to registered users displayed at full
>>> screen with all Mapguide features enable.
>>> Can it be done? If so, any help is appreciated.
>>> I am using MGOS 2.1 with PHP.
>>> Regards
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
