[mapguide-users] SHP Feature source update
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Nov 30 03:14:20 EST 2009
MgLayer is the name of the class that is used for runtime layers.
Im guessing that layer.GetClassName() returns "MgLayer".
Have you tried with GetFeatureClassName():
http://mapguide.osgeo.net/files/mapguide/docs/webapi/d6/de2/class_mg_layer_a983e24398d337eff4809830993eb992.html#a983e24398d337eff4809830993eb992
Regards, Kenneth Skovhede, GEOGRAF A/S
smeurant skrev:
> Hi all,
> I try to update a SHP feature source using the MapGuide Java API with a
> servlet.
> But i have a problem with this step :
> featureService.UpdateFeatures(FeatureSourceID,featureCommandCollection,false);
> Like say the API doc , it return a MgPropertyCollection.
> And in this propertyCollection, i found a error msg sent by FDO :
> An exception occurred in FDO component.
> FDO class 'MgLayer' not found in schema.
> Is the problem come from my implementation or, is it a bug in MGOS 2.1b?
> Thanks for your help
> P.S : You can find the full servlet implementation in the attached file
> http://n2.nabble.com/file/n4076428/updateFeatureSource.java
