[mapguide-users] Mapguide 2.0.2 and SQLite
Flipper
scotth at mpowerinnovations.com
Thu Oct 1 11:10:14 EDT 2009
No It errors out before it even gets to the Point that I can see the
Layers/Schema of the SQLite datasource
Doesnt matter if its Maestro or Studio...It seems to be in The mapguide
2.0.2 itself...I can't figure it out...
I really like the concept of moving this person over to it because of their
GIS experience level, its a great first step into GeoSpatial databases for
them and cuts out the server side Network connection which is a nagging
problem...But unfortunately they are on 2.0.2 and Studio, They dont have
money to buy Enterprise this year, which means no Option to upgrade their
Studio license, and Id rather not downgrade them to 2.0.0 since 2.0.2 has so
many bug fixes (minus this one) in it.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Can you render the layer if you put it in a map?
> The preview function tries to read the spatial context to determine the
> display extents of the preview, but since that fails, it won't preview.
> When you view the layer in a map, it won't try to read the spatial
> extents.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Flipper skrev:
>> Traian Was Extremely helpful in getting a build of the SQLite drivers
>> that
>> were built on FDO 3.3 and 3.4 http://13-9.com/ LINK that work
>> Extremely
>> well for me on Mapguide Open Source 2.0.0...My problem is that it does
>> not
>> work on 2.0.2 Which is FDO 3.3.1, but discussing with him, Traian
>> compiled
>> with the latest code in the 3.3 branch, which is 3.3.1. It should not
>> make
>> any difference though, since 3.3.1 only has a few bug fixes on top of
>> 3.3.
>> And it still worked on 2.0.0 and not 2.0.2...Traian can';t really help me
>> any further since this no longer seems to be an issue with the driver but
>> with the MG release...THANKS SOO MUCH FOR YOUR HELP TRAIAN!!!!!
>> I've USED the same versions of Maestro and of Mapguide Studio 2009 on my
>> 2.0.0 product to Author out SQLIte layers...both work....
>> On 2.0.2 Mastro gives me this error when I try to validate a data source
>> connection ...
>> Validating file:
>> Session:663cacec-0000-1000-8000-002219fbc74d_en_7F0000010AFC0AFB0AFA//f4004ed7-a9ec-4586-8395-c94fb7121247.FeatureSource
>> Warning - OSGeo.MapGuide.MaestroAPI.FeatureSource: No spatial contexts
>> found
>> Error - OSGeo.MapGuide.MaestroAPI.FeatureSource: Failed to read schema
>> description: The remote server returned an error: (559)
>> MgNullReferenceException.:
>> Null reference.
>> Exception occurred in method MgServerDescribeSchema.ExecuteDescribeSchema
>> at
>> line 62 in file
>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
>> in Studio on 2.0.2 I get a "Null Reference" error When i try to do a
>> preview
>> on the Data connection and a Null Reference Pop up error and a Resource
>> Id
>> does not belong to a valid Feature Source Popup when i try to Create a
>> layer
>> from the datasource. Also in Studio the interface does not give me an
>> area
>> to enter a filename, on one machine, but on a machine where I did install
>> the newest 3.3.1 FDo driver it does but doesnt give me a UseFdo metadata
>> option like 2.0.0 did.
>> Anybody have any ideas...Id just go to 2.1 myself or downgrade if it
>> werent
>> for the fact that its for others and not myself....Any help would be
>> extremely appreciated
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Mapguide-2-0-2-and-SQLite-tp3732265p3749717.html
