[mapguide-users] Fusion and Open layers Coordinate systems
Scott hameister
scotth at mpowerinnovations.com
Wed Oct 7 12:11:21 EDT 2009
NEVER mind I see Openlayers doesn't have such an option as to create a
custom coordinate system...That would have solved everything.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: Wednesday, October 07, 2009 11:02 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion and Open layers Coordinate systems
I'm currently working on a patch to retrieve the projection info from
the map definition for MapGuide. The problem is that MG uses WKT and
OpenLayers/Fusion uses EPSG codes and MG doesn't always have an EPSG/WKT
mapping available. So I will be implementing this so that if MG returns
a valid EPSG code it will use that, otherwise it will take a value from
the ApplicationDefinition file, and if there still isn't an EPSG code
available then the projection will be set to the OpenLayers default of
EPSG:4326.
Mike
Flipper wrote:
> Im trying my hand at some Open Layers programming. I'm trying to set the
maps
> Coordinate system to match Mapguides, So I decided to peek into Fusion....
> One thing for the life of me I can't find is where fusion sets the
OpenLayer
> Maps Coordinate system. I know Open layers uses Proj 4, and Mapguide Can
use
> both cs-map and Proj4...I know how to get the coordinate system
Description
> out of Mapguide...But how do I push it back into OpenLayers Using my
PROJCS
> system...
> Or worded Much simpler...How/Where does Fusion do this to openLayers...I
> want this to work on anymap...so I don't want to hard code a EPSG code
into
> it, and several users will have Non PROJ4 coordinate systems, like Local
> County Coordinate systems that CS-MAP allows them to use...
> ANYONE?
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
madair at dmsolutions.ca
http://www.dmsolutions.ca
http://research.dmsolutions.ca
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
